Beam Deflection and Stress Equations and Calculator Beam Uniform Loading
Stress Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Uniform loading Applied
Reaction and Shear Equation
Bending Moments Equation
W = | Load, Total | lbf | (N) |
w = | Unit Load | lbs/in | (N/mm) |
y = | Deflection | inches | (mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Shear Load | lbf | (N) |
Mmax = | Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Stress Deflection Equations / Calculation - Fixed at One End, Supported at the Other, Load at any Point
- Beam Stress Deflection Equations / Calculation - Fixed at Both Ends, Load at Center
- Beam Stress Deflection Equations / Calculation - Fixed at Both Ends, Load at any Location
- Beam Stress Deflection Equations / Calculation with Uniform Loading
- Beam Bending Stress Deflection Equations / Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads
- Beam Stress Deflection Equations / Calculation - Continuous Beam, with Two Equal Spans, Uniform Load
- Beam Stress Defection Simply Supported on Both Ends Under Superimposed Loading Equations
- Bearing Stress Between Angled Strut and Supporting Pin Equations and Calculator
- Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
