Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
Structural Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
Beam Moments Equation
Bending Moments Equation
Stress Maximum Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Beam Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
Vmax = Beam Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
σmax = Beam Stress max. psi (N/mm2)
