Structural Shapes Steel, Aluminum ASTM, BS, EN, ISO Sizes Tables - Engineers Edge
Structural Materials Menu
Engineering Materials Menu
- The following are to links to Structural Shapes Steel, Aluminum ASTM, BS, EN, ISO, GOST Sizes Tables .
- Should you find any errors omissions broken links, please let us know - Feedback
- Do you want to contribute to this section? See Premium Publisher Program
** Search this PAGE ONLY, click on Magnifying Glass **
- Structural Steel AISC Shapes Properties Viewer
- Polar Area Moment of Inertia
- Strength of Materials and Applications
- Young's Modulus
General Structural Design
ASTM, ANSI, ASME Structural Shape Sizes
- AISC Ultimate Structural Shapes Properties Viewer
- American Standard Aluminum Channel Sizes Table
- Aluminum Channel Table Aluminum Association Standard
- Standard Channels per. Aluminum Association Standard Dimensions, Areas, Weights and Section Properties
- Standard Aluminum Angle Equal Leg Aluminum)
- Standard Aluminum Channel, Standard Aluminum
- Aluminum B308 Aluminum Structural Shape Anlge Unequal Legs
- Aluminum I-Beam Dimensional Sizes, Area Moment of Inertia Table - Aluminum Association Standard I-Beam Dimensions, Areas, Weights and Section Properties
- AISC, ASTM Channel Steel
- AISC, ASTM Wide Flange #1 Steel
- AISC, ASTM Wide Flange #2 Steel
- AISC, ASTM S Narrow Flange I Beam Steel
- AISC, ASTM Angle Steel #1
- AISC, ASTM Angle Steel #2
- AISC, ASTM Angle Unequal Leg Aluminum
- Standard Aluminum I-Beams Aluminum
- AISC, ASTM Steel Angle Unequal Leg Steel
- AISC, ASTM Structural Tees Cut from W Flange
BS, EN, ISO, BSI Structural Shape Sizes
- AISC, ASTM S Flange (Steel)
- Steel Section Properties Chart Narrow I-Beam BS 4-1 | EN 1993-1-1
- Steel Section Properties Chart Wide I-Beam BS 4-1 | EN 1993-1-1
- Structural Steel Angle Section Properties, Unequal Leg BSI BS EN 10056
- Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
- Structural Steel I-Beam Universal Flange Section Properties BS 4-1:2005
- Structural Steel I-Beam Universal Flange Section Properties BS4: Part 1: 1993
Indian Standards Per. IS 808
SST ASIC Structural Shapes
AISC SST Tube Design & Dimensional Data
GOST Standard Structural Shapes
Properties of Rolled-Steel L Shapes, Angles with Equal Legs. Standard GOST 8509-72
