Bending, Deflection and Stress Equations Calculator for
Fixed at Both Ends, Load at Center
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends, Load at Center.
Moment and Loads at Supports
M = Wl/8
W1=W/2
Open: Moment and Loads at Supports Calculator
Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Stress at any Given Point
Between each end and load
Open: Stress Between Each Support and Load Calculator
Stress at Critical Locations/Points
Stress at ends
Stress at Load
Open: Stress at each end and at Load Calculator
Note: These are the maximum stresses and are equal and opposite.
Stress is zero at x = (1⁄/4)l
Deflection at any Point
Maximum deflection, at load
Open: Stress at each End and at Load Calculator
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
u = Some distance as indicated inches (mm)
a, b, c & d = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
