Engineers Edge Forums and Premium Membership
Signup today! Register Account or Login
Engineer Edge has been in operation since early 2000 and serves over 1.6 million visitors monthly. Engineers Edge is absolutely the preferred online destination for designers, engineers and manufacturing
professionals, where all can quickly find a variety of information to aid in the solution of typical and complex
technical problems.
We have created membership access options to better fund the support and development of existing and new online resources. We are committed to bring you PRACTICAL online resources and tools to assist you in your technical needs!
Engineers Edge Premium Membership
  • All engineering, manufacturing and design calculators.
  • Access downloads to ALL excel spreadsheet applications (keep checking back as we are always adding new additions).
  • Online ebooks
    • Geometric Boundaries II, The Interpretation and Application to ASME Y14.5-2009 GD&T (600 + pages)
    • Engineering Design for Manufacturing and Assembly - (over 1000 page of data).
    • Numerous white papers and presentation related to engineering and manufacturing process, operations, etc.
  • Limited advertising to optimize printing and web page load speeds.
  • Much more!
Membership Subscription Types
  • Engineering Forums and Newsletter Subscription - Free. This FREE membership gets you access to the engineering forums and you will get periodic updates on new resources and tools by email.
  • Limited Advertising 1 Year. Advertising bars on left and right side and bottom of web page are removed for quicker web page loads times.
  • Premium Membership Monthly. Access all web site engineering books, resources, calculators and more (see above)! Renews until cancelled.
  • Premium Membership Annual (1 year). Access all web site engineering books, resources, calculators and more (see above)! Renews until cancelled.
  • Student Premium Membership (1 year). Access all web site engineering books resources, calculators and more (see above)! Renews until cancelled. REQUIRES A VERIFIABLE SCHOOL EMAIL (University, College, High School Etc.). Signups without a school email can be processed with an copy/image of a school ID or equivalent emailed to webmasteratengineersedge.com. Unverified students are processed as monthly signups.. Substitute" at " with @ when emailing.
  • Premium Membership - Limited Advertising (1 year). Access all web site engineering books resources, calculators and more (see above) and removes advertising from most web pages! Renews until cancelled.
  • Small Group rates are available (less than twenty)! Contact us with our Feedback Form:
Noted Premium Membership Resources (Partial)
Premium Member Resources
(Subscription Required)
What's New!
Venturi Flow Equation and Calculator
A Venturi meter is used to measure the flow rate through a tube or volumetric flow rate, Q.
Pressure Losses for Fluid Flow in 90° Pipe Bends
Pressure losses were determined for nine 4-inch steel, 90° pipe bends of radii from 6 to 80 inches. The results are discussed in relation to those found by previous investigators under comparable test conditions.
Design for 3D Metal Sintering Printing
Direct metal laser sintering (DMLS) process is Sometimes referred to as metal 3d printing or a metal 3d printer, DMLS uses a laser beam to melt 20-40 micron layers of metal powder on top of each other to create metal parts.
Design for Compression Molding Plastics Thermosets
Compression molding compounds of thermosetting materials, or thermosets, when subjected to heat and pressure within the confines of a mold, cure or set into an infusible mass . An irreversible chemical change, involving the cross-linking of molecules of the material , takes place, and a solid part is formed .
Sositar Mould Co.,LTD
Plastic mold making and injection molding, prototypes, silicone and rubber molding manufacturing services.
Design for Machining Fiberglass and Composites
Machining Composites poses unique challenges for manufacturing and design engineering to meet an end items requirements. Composites are group of materials that include Random Fiber, Prepreg, intermediate Layers and Vacuum Bag construction.
Minimum Fillet Weld Size per AWS D1.1 Table
When weld fillet size is not specified on engineering drawing, the following general guidance apply per. AWS D1.1.
Design for Thermoforming Vacuum
The process of evacuating air from the sealed space between the hot sheet and the mold, thus allowing atmospheric pressure (14.7 p.s.i .) to force the sheet to conform with the contour of the mold.
Projection Welding Review and Design Considerations
Projection welding is an electric resistance welding process that produces welds by the heat obtained from the resistance to the flow of the welding current. The resulting welds are localized at predetermined points by projections, embossments, or intersections
Cost of Welding Review Equation and Calculator
Welding costs can be estimated using one of three basic approaches : Cost per unit. Cost per length. Cost per weight.
