Bending, Deflection and Stress Equations Calculator for
Continuous Beam, with Two Equal Spans, Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a ontinuous Beam, with Two Equal Spans, Uniform Load.
Section Modulus Z
Z = I/c
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Stress at any Given Point
Open: General Stress at any Given Point Calculator
Deflection at any Point
Open: Deflection any Given Point Calculator
Critical Deflections
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
u = Some distance as indicated inches (mm)
a, b = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition
  • Machinery's Handbook, 23st Edition
  • Machinery's Handbook, 27st Edition
