Bending, Deflection and Stress Equations Calculator for
Fixed at One End, Supported at the Other, Load at any Point
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at One End, Supported at the Other, Load at any Point.
Calculator for Fixed at One End, Supported at the Other, Load at any Point
Lengths m & n
(Used in many equations)
m = (l + a)(l + b) +al
n = al(l + b)
Open: Lengths m and n Calculator
Loads and Moment at Reaction points as Defined
Open: Loads at Reaction points as Defined Beam Calculator
Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Stress at any Given Point
Between point of fixture and load
Between support and load
Open: Stress Between point of fixture and load and Support Calculator
Stress at Critical Locations/Points
Open: Greatest Positive Stress at point of fixture and Negative Stress at Load Calculator
Deflection at any Point
Open: Deflection at point of fixture and load and Between Support at Load Calculator
Critical Deflections
Open: Deflection at Load Calculator
Deflection at Load Equation
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
u = Some distance as indicated inches (mm)
a, b, c & d = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
m, n = Some calculated distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
