Structural Beam Deflection Equations and Stress Formula and Beam Deflection Calculators
Engineering Calculators Menu
Engineering Analysis Menu
Structural Beam Deflection, Stress Formula and Calculator: The follow web pages contain engineering design calculators that will determine the amount of deflection and stress a beam of know cross section geometry will deflect under the specified load and distribution. Please note that SOME of these calculators use the section modulus of the geometry cross section ("z") of the beam. You will need to determine the moment of inertia of the cross section and the distance from the neutral axis to the edge of your geometry.
Beam Deflection & Stress
Beam Supported on Both Ends Uniform Loading Stress, Deflection Equation and Calculator using total applied load and line load.
Stress Equation and Calculator for Beam Supported on Both Ends Single Load at Center Constant cross section beam Stress, Deflection Equation and Calculator using single applied load at center
Equation and Calculator for Stress and Deflection of Beam Constant cross section beam supported on both Ends Loaded at any Location using single applied load at center
Stress and Definitions Equations and Calculator for Structural Beam Beam Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
Beam Stress & Deflection Equation and Calculator For Beam at Supported at Both Ends and Two equal Loads Beam Supported on Both Ends With Two Loads Applied at Equal Length From Structural Ends.
Beam Stress and Deflection Equation and Calculator Structural Beam Deflection, Stress, Bending Equation and Calculator for a Beam with Ends Overhanging Supports and Two loads.
Beam Stress & Deflection Equations / Calculator Beam with Two Equal Loads applied at Symmetrical Locations Stress, Bending Equation and calculator for a Beam with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations.
Structural Beam Bending Stress Calculator Calculation Simply Supported on Both Ends Under Superimposed Loading Equations
Beam Stress Calculator Simply Supported Beam with Superimposed Loading Equations Deflection, Stress, Bending Equations and calculator for a Simply Supported Beam on Both Ends Under Superimposed Loading Equations.
Beam Stress & Deflection Equations / Calculator Cantilevered Beam Structural Beam Deflection, Stress Equations and calculator for a Cantilevered Beam with Uniform Load.
Beam Calculator Cantilevered Beam with One Load Applied at End Structural Beam Deflection, Stress, Bending Equations and calculator for a Cantilevered Beam with One Load Applied at End.
Cantilevered Beam Stress & Deflection Equations and Calculator Structural Beam Deflection, Stress, Bending Equations and calculator for a Cantilevered Beam with Load at Location Between Support and Load.
Beam Defection and Stress Free and Guided on One End, Rigid one End With Uniform Load Structural Deflection, Stress, Bending Equations and Calculator for a Beam Free and Guided on One End, Rigid other End With Uniform Load.
Structural Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
Constant Cross Beam Section Shear, Stress Equations and Calculator Structural Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Tapered Load
Cantilevered Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One with Tapered Load Structural Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Tapered Load.
Beam Stress, Defection and Slope supported One End Cantilevered with Reversed Tapered Load Structural Beam Deflection, Shear, Slope and Stress Equations and calculator for a Beam supported One End Cantilevered with Tapered Load.
Deflection, Shear and Stress Equations and Calculator Cantilevered Beam with Limited Tapered Load Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limited Tapered Load
Cantilevered Beam Deflection, Shear and Stress Equations and Calculator Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limited Tapered Load
Shear and Stress Equations and calculator for a Beam Triangular Distributed Load Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Triangular Distributed Load
Beam Distributed Load Deflection, Shear and Stress Equations and Calculator Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Partial Distributed Load
Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated. Beam Deflection, Shear and Stress Calculator for Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated.
Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load.
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load.
Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied
Beam supported One End, Pin Opposite End and Single Moment at Defined Center Location Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Single Moment at Defined Center Location
Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End Deflection and Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
Stress Equations and Calculator for a Beam supported One End, , Cantilevered at Defined Location and Distributed Load Between Supports Shear, Deflection and Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Distributed Load Between Supports
Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports Shear, Deflection and Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports
Stress Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Single Moment Applied at End Stress Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Single Moment Applied at End
Stress Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Uniform loading Applied Stress Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Uniform loading Applied
Stress Deflection Equations and Calculator Beam Supported Uniform loading Applied on Cantilevered End Stress Deflection Equations and Calculator Beam Supported Uniform loading Applied on Cantilevered End
Stress Deflection Equations and Calculator Beam Supported Uniform loading Applied Stress Deflection Equations and Calculator Beam Supported Uniform loading Applied
Stress Deflection and Moment Equations and Calculator Beam Supported Uniform loading Applied Stress Deflection Moment Equations and Calculator Beam Supported Uniform loading Applied
Beam Stress & Deflection Equation Calculator Supported on One End, Rigid one End With Uniform Load Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Supported on One End, Rigid one End With Uniform Load.
Beam Stress & Deflection Equations / Calculator Free and Guided on One End, Rigid one End With Single Load Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Free and Guided on One End, Rigid one End With Uniform Load and Bending moment.
Beam Stress & Deflection Equations / Calculator Free and Guided on One End Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with bending moment applied
Beam Stress & Deflection Equations / Calculator Moment Applied at Defined Location Beam Stress & Deflection Equations / Calculator Moment Applied at Defined Location
Stress Deflection Moment Equations and Calculator Beam Supported Partial Uniform loading Applied Stress Deflection Moment Equations and Calculator Beam Supported Partial Uniform loading Applied
Stress Deflection Moment Equations and Calculator Beam Supported Partial Distributed Uniform loading Applied Stress Deflection Moment Equations and Calculator Beam Supported Partial Distributed Uniform loading Applied
Stress Deflection Moment Equations and Calculator Beam Supported Tapering Load Applied Stress Deflection Moment Equations and Calculator Beam Supported Tapering Load Applied
Stress Deflection Strain Equations and Calculator Beam Supported Tapering Load Applied Stress Deflection Strain Equations and Calculator Beam Supported Tapering Load Applied
Stress Deflection Moment Equations and Calculator Beam Supported Partial Tapering Load Applied Stress Deflection Moment Equations and Calculator Beam Supported Partial Tapering Load Applied
Stress Deflection Strain Moment Equations and Calculator Beam Supported Partial Tapering Load Applied Stress Strain Deflection Moment Equations and Calculator Beam Supported Partial Tapering Load Applied
Beam Cross Section Stress Equations / Calculator - Both Ends Overhanging Supports Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with Both Ends Overhanging Supports, Load at any Point Between.
Beam Stress Deflection Equations / Calculator - Fixed at One End, Supported at the Other, Load at Center Beam Deflection, Stress, Bending calculator for a Beam Fixed at One End, Supported at the Other
Beam Stress Deflection Equations / Calculator - Fixed at One End, Supported at the Other, Load at any Point Stress, Bending Equations and calculator for a Beam Fixed at One End, Supported at the Other, Load at any Point.
Beam Stress Deflection Equations / Calculator - Fixed at Both Ends, Load at Center Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends, Load at Center.
Beam Stress Deflection Equations / Calculator - Fixed at Both Ends, Load at any Location Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends, Load at any location.
Beam Stress Deflection Equations / Calculator with Uniform Loading Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends with Uniform Loading.
Beam Stress Deflection Equations / Calculator with Partial Uniform Loading Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends with Partial Uniform Loading.
Beam Stress Deflection Equations / Calculator with Partial Tapering Loading Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends with Partial Tapering Loading.
Beam Stress Deflection Equations / Calculator with Fixed Ends Tapering Loading Beam Stress Deflection Equations / Calculator with Fixed Ends Tapering Loading
Beam Stress Deflection Equations / Calculator with Fixed Ends Moment Applied Beam Stress Deflection Equations / Calculator with Fixed Ends Moment Applied
Beam Bending Stress Deflection Equations / Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads Deflection, Stress, Bending Equations and calculator for a Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads.
Beam Stress Deflection Equations / Calculator - Continuous Beam, with Two Equal Spans, Uniform Load Deflection, Stress, Bending Equations and calculator for a continuous Beam, with Two Equal Spans, Uniform Load. c = Distance neutral axis to extreme fiber
Area Moment Methos to Calculate Deflection in Beams
Area Moment Methods to Calculate Deflection in Beams No Calculator! Calculation of deflections and redundant reactions for beams on two supports can be made by the use of the area-moment method.
Circular plate, uniform load, edges simply supported equation and calculator.
Circular plate, uniform load, edges simply supported equation and calculator Maximum stress and deflection for circular flat plates subject to concentrated or distributed loads (pressure) with the edge either clamped or supported.
Circular plate, uniform load, edges clamped equation and calculator
Circular plate, uniform load, edges clamped equation and calculator Circular flat plates subject to concentrated or distributed loads (pressure) with the edge either clamped or supported.
Circular plate, concentrated load, edges clamped equation and calculator
Circular Plate Concentrated Load Floating Equation and Calculator Circular Plate Concentrated Load Floating Equation and Calculator
Circular Plate Concentrated Load Edges Fixed Support Equation and Calculator Circular Plate Concentrated Load Edges fixed Supported Equation and Calculator
Rectangular plate, uniform load, simply supported equations and calculator
Rectangular plate, uniform load, simply supported equations and calculator Rectangular plate, uniform load, simply supported (Empirical) equations and calculator Since comers tend to rise off the supports, vertical movement must be prevented without restricting rotation.
Rectangular plate, uniform load, clamped (Empirical) equations and calculator Rectangular plate, uniform load, clamped (Empirical) equations and calculator Symbols used: a = minor length of rectangular plate, (m, in) b = major length of rectangular plate, (m, in) p = uniform pressure loading, (N, lbs) v = Poisson’s ratio
Rectangular plate, concentrated load at center, simply supported (empirical) equation and calculator Rectangular plate, concentrated load at center, simply supported (empirical) equation and calculator. The load is assumed to act over a small area of radius e.
Concentrated load at center of Plate, clamped edges (empirical) equation and calculator Rectangular plate, circular concentrated load at center, clamped edges (empirical) equation and calculator.
Combined Stress Circular Cantilever Beam in Direct Compression and Bending Stress Equations and Calculator Circular Cantilever Beam in Direct Compression. For every calculated normal stress there is a corresponding induced shear stress; the value of the shear stress is equal to half that of the normal stress.
Circular Cantilever Beam in Direct Tension and Bending Equations and Calculator
Circular Cantilever Beam in Direct Tension and Bending Stress Equations and Calculator Circular Cantilever Beam in Direct Tension. For every calculated shear stress t here is a corresponding induced normal stress; the value of the normal stress is equal to that of the shear stress.
Rectangular Cantilever Beam in Direct Compression and Bending Equations and Calculator
Beam in Direct Compression and Bending Stress Equations and Calculator Circular Cantilever Beam in Direct Compression and Bending Equations and Calculator
Rectangular Cantilever Beam in Direct Tension and Bending Stress Equations and Calculator Rectangular Cantilever Beam in Direct Tension and Bending Stress and Deflection Equation and Calculator
Combined Loading on Circular Beam or Shaft in Direct Compression and Bending Equation and Calculator
Combined Loading on Circular Beam or Shaft in Direct Compression and Bending Stress Equation and Calculator Combined Loading on Circular Beam or Shaft in Direct Compression and Bending Equation and Calculator
Combined Loading on Circular Beam or Shaft in Direct Tension and Bending Equation and Calculator
Combined Loading on Circular Beam or Shaft in Direct Tension and Bending Stress Equation and Calculator Circular Beam or Shaft Combined Loading in Direct Tension and Bending Equation and Calculator:
Combined Loading on Rectangular Beam or Shaft in Direct Compression and Bending Equation and Calculator
Combined Loading on Rectangular Beam or Shaft in Direct Compression and Bending Stress Equation and Calculator Rectangular Beam or Shaft in Direct Compression and Bending Equation and Calculator:
Combined Loading on Rectangular Beam or Shaft in Direct Tension and Bending Equation and Calculator
Rectangular Beam or Shaft in Direct Tension and Bending Stress Equation and Calculator Rectangular Beam or Shaft in Direct Compression and Bending Equation and Calculator:
Combined Loading on Circular Shaft in Direct Compression and Torsion Stress Equation and Calculator Circular Shaft in Direct Compression and Torsion Equation and Calculator:
Loading on Circular Shaft in Direct Tension and Torsion Stress Equation and Calculator Combined Loading on Circular Shaft in Direct Tension and Torsion Equation and Calculator:
Combined Loading on Offset Link, Circular Cross Section, in Direct Tension Equation and Calculator
Combined Loading on Offset Link, Circular Cross Section, in Direct Tension Stress Equation and Calculator Loading on Offset Link, Circular Cross Section, in Direct Tension Equation and Calculator:
Combined Loading Offset Link, Circular Cross Section, in Direct Compression Equation and Calculator
Combined Loading Offset Link, Circular Cross Section, in Direct Compression Stress Equation and Calculator Maximum Nominal Tensile or Compressive Stress Maximum Nominal Shear Stress
Combined Loading Offset Link, Rectangular Section, in Direct Tension Stress Equation and Calculator Rectangular Section, in Direct Compression Stress Equation and Calculator
Combined Loading Offset Link, Rectangular Section, in Direct Compression Stress Equation and Calculator Direct Compression Stress Equation and Calculator Loading Offset Link, Rectangular Section
Cored Laminate Composite Stiffness Calculator
Cored Laminate Composite Stiffness Calculator Here also are discussed the effects of facing and core stiffness on sandwich bending stiffness so that the degree of approximation implied by simplified formulas neglecting facing and core stiffness is known.
W-Flange Overhead Monorail Beam Analysis Calculator
W-Flange Overhead Monorail Beam Analysis Calculator For W-shaped Under hung Monorails Analyzed as Simple-Spans with / without Overhang Per AISC 9th Edition ASD Manual and CMAA Specification No. 74 (2004)
S-Flange Overhead Monorail Beam Analysis Calculator
S-Flange Overhead Monorail Beam Analysis Calculator S-shaped Under hung Monorails Analyzed as Simple-Spans with / without Overhang Per AISC 9th Edition ASD Manual and CMAA Specification No. 74 (2004)
K-Series Joist Deflection and Stress Analysis Calculator
K-Series Joist Deflection and Stress Analysis Calculator K-Series Joists Specifications Designations: 8K1 to 30K12 Depths: 8 to 30 in. Standard Seat Depth (Height): 2.5 in. Span Range: 8 to 60 ft. ASD Load Range: 127 to 550 plf LRFD Load Range: 190 to 825 plf Maximum Span/Depth Ratio: 24
LH-Series Joist Deflection and Stress Analysis Calculator LH, Long span Steel Joists Designations: 18LH02 to 48LH17 Depths: 18 to 48 in. Types: Parallel Chord, Single Pitch, Double Pitch; Under slung or Bottom Chord Bearing
Davits
Lifting Boom, Davits Application and Design Equations
Davits refer to single mechanical arms with a winch for lowering and raising objects. A davit is commonly used system designed to lower an emergency lifeboat from a ship to the embarkation level to be boarded.
Tension Compression Machine Feature Equation and Calculator
Principal and Von-Mises Stress Equations and Calculator
Principal stresses for 2 dimensional plane stress system and von-mises stress equations and calculator.
MOhr's Circle
Mohr's Circle Equation and Calculator
Mohr's circle is a geometric representation of the 2-D transformation of stresses.
Single-Span Beam Deflection for Simple, Propped, Fixed or Cantilever Beams. - Include Shear and Moment Diagram.
NOTE: Large web page that opens in pop-up window.
Section Modulus
Section Modulus - Plastic Section Modulus (PNA) Section modulus is a geometric property for a given cross-section used in the design of beams or flexural members.
Fixed Pin Cantilever Beam Design
Fixed Pin Cantilever Beam Design Calculator Designing a Fixed-Pinned Cantilever Beam
Plate Deflection & Stress
Flat Plate Deflection & Stress Calculator Assumptions: The plate is flat, of uniform thickness, and of homogeneous isotropic material; the thickness is not more than about one quarter of the least transverse dimension, and the maximum deflection is not more than about one-half the thickness;
Axial Load Capacities Single Plates Calculator
Axial Load Capacities Single Plates Calculator Axial Load Capacities of a Single Plate Equation and Calculator
Tapered BEam Deflection Stress
Tapered Snap Fit Beam Bending Equation and Calculator Plastic Snap Fit Stress, deflection and moment equation and calculator
Concrete Rectangular Beam Section Analysis Calculator
Concrete Rectangular Beam Section Analysis Calculator Concrete Rectangular Beam Section Analysis Calculator Beam or One-Way Type Shear per Per ACI 318-05 Code
Rectangular Concrete Beam Section Analysis Crack Control - Distribution of Flexural Reinforcing
Rectangular Concrete Beam Section Analysis Crack Control - Distribution of Flexural Reinforcing Concrete Beam Section or Slab Analysis Per ACI 318-05 and ACI 318-95 Codes
Rectangular Concrete Beam Section Analysis Beam Torsion and Shear Concrete Beam Torsion and Shear Per ACI 318-05 Code
Bolt Shear
Bolt Shear AISC Stress Calculator Calculator will determine bolt stress in tension and shear per AISC 9th Edition Manual (ASD)
Eccentric Loading On Bolt Group One Vertical Row Calculator
Eccentric Loading On Bolt Group One Vertical Row Calculator - Based on the Instantaneous Center of Rotation Method and Alternate Method 2, Using Table XI from AISC 9th Ed. Manual (ASD) - page 4-62
Eccentric Loads on Bolt Groups for Two Vertical Rows of Bolts Based on the Instantaneous Center of Rotation Method and Alternate Method 2 Using Table XII from AISC 9th Ed. Manual (ASD) - page 4-63
/calculators/bolt-group/BOLTGRPXIII/bolt-grp-xiii.htm
Structural Eccentric Loading on Bolt Group - For Two Vertical Rows Calculator
Eccentric Loading on Bolt Pattern for Vertical Rows of Four Based on the Instantaneous Center of Rotation Method and Alternate Method 2 Using Table XVII from AISC 9th Ed. Manual (ASD) - page 4-68
Column Bucking
Ideal Pinned Column Buckling Calculator When a column buckles, it maintains its deflected shape after the application of the critical load. In most applications, the critical load is usually regarded as the maximum load sustainable by the column.
Pressure Vessel
Cylinder Stress and Deflection with Applied Torsion Equations and calculator for determining the cylinder stress and deflection with a known applied torsion or torque.
Stress Concentration
Stress Concentration Cylinder feature with Axial Loading Stress concentration on a selected radius of a shaft with axial loading.
Thin Wall Pressure Vessel
Thin Wall Pressure Vessel Hoop Stress Hoop stress is twice that of the longitudinal stress for a thin wall pressure vessel. Therefore, the Hoop stress should be the driving design stress.
Thin Wall Pressure Vessel Longitudinal Stress Longitudinal Stress in a thin wall pressure vessel use the following calculator
Steel W & S Flange Beam and Column Analysis / Code Check Calculator Calculator and linked equations will determine the column loading and applied stress for AISC wide, narrow and other flange structural sections.
Torsion Stress Calculator and Equations Torsion is the twisting of an object due to an applied torque . It is expressed in newton meters(N·m) or foot-pound force (ft·lbf).
Bolt or Pin Single Shear Equation and Calculator
Bolt or Pin Single Shear Equation and Calculator Bolt or Pin In Single Shear Equation and Calculator. Keep units consistent when performing calculations.
Bolt or Pin Double Shear Equation and Calculator Double Shear Equation and Calculator. Keep units consistent when performing calculations
Bolt Single and Double Shear and Tension Stress Analysis Calculator per AISC bolt stress in tension and shear per AISC 9th Edition Manual (ASD)
Contribute Article
