Bending, Deflection and Stress Equations Calculator for
Cantilevered Beam with One Load Applied at End
Structural Beam Deflection, Stress, Bending Equations and calculator for a Cantilevered Beam with One Load Applied at End.
Open
Bending, Stress Cantilevered Beam One Load Applied at End Calculator
Stress at specific point
Stress at the support (must be constant cross section)
Deflection at specified point
Deflection at the unsupported end
E =  Modulus of Elasticity psi
(N/mm2)
W =  Load lbs (N)
s =  Stress at the cross-section being evaluated lbs/in2 (N/mm2)
y = Deflection inches (mm)
Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 408 or,
  • Machinery's Handbook, 23st Edition, Page 264 or,
  • Machinery's Handbook, 27st Edition, Page 265
