Weld Process and Joint Design and Engineering Formula Menu
Applications & Design
  • The following are to links of Welding engineering and design equation, tips and specifications.
  • Should you find any errors omissions broken links, please let us know - Feedback
  • Do you want to contribute to this section? See Premium Publisher Program
Weld Resources General
Spot Weld Design Equations and Calculators
Welding Types and Processes
Weld Joint Design Equations and Calculations
Table of welds and related equations for determining stress under specified loading conditions.
σ = Normal Stress, MPa (psi)
τ = Shear Stress, MPa (psi)
Mb = Bending Moment, Nm (lbf in)
Mt = Torque N-m (lbf-in)
P = Applied Load, kN (lbf)
L = Linear Distance, m (in)
hn = Size of Weld, m (in)
l = Length of Weld, m (in)
Weld Design Configuration Notes: Calculators Require Premium Membership
Weld Case #1
Axial Load Full Penetration Weld equal to plate thickness stress.
Open: Axial Load Full Penetration Weld Calculator
Weld Stress Calculations #2
Axial Normal Load Partial Penetration Weld thickness stress equation and calculator.
Open: Axial Normal Load Partial Penetration Weld Calculator
Tee Section Load Full Penetration Weld Stress Equation and Calculator .
Tee Section Load Full Penetration Weld Stress Equation and Calculator.
Open: Tee Section Load Full Penetration Weld Stress Calculator
Tee Section Load Full Penetration Weld Moment Loading Applied Stress Calculator
Tee Section Load Full Penetration Weld Moment Loading Applied Stress Calculator.
Open: Tee Section Load Full Penetration Weld Moment Loading Applied Stress Calculator
Tee Section Load Full Penetration Weld Perpendicular Loading Applied Stress Calculator
Tee Section Load Full Penetration Weld Perpendicular Loading Applied Stress Calculator.
Open: Tee Section Load Full Penetration Weld Perpendicular Loading Applied Stress Calculator
Butt Weld Bending Moment Load Full Penetration Weld Stress Stress Calculator.
Open: Butt Weld Bending Moment Load Full Penetration Weld Stress Stress Calculator.
Partial Penetration Weld Bending Moment Weld Stress.
Open: Partial Penetration Weld Bending Moment Weld Stress Calculator.
Tee Section Load Partial Penetration Weld Perpendicular Loading Applied Stress Calculator.
Open: Tee Section Load Partial Penetration Weld Perpendicular Loading Applied Stress Calculator
Tee Section Loaded Partial Penetration Weld Bending Moment Applied Stress Calculator
Open: Tee Section Loaded Partial Penetration Weld Bending Moment Applied Stress Calculator
Stress created for a Partial Penetration Weld Load Perpendicularity Weld Stress.
Open: Stress created for a Partial Penetration Weld Load Perpendicularity Weld Stress.
Stress created for the three plate splice configuration weld equals plate thickness.
Open: Stress created for the three plate splice configuration weld equals plate thickness.
Two Plate Weld Axial Load Weld Stress Calculator
Open: Two Plate Weld Axial Load Weld Stress Calculator
Stress created for the two plate parallel weld configuration.
Open: Stress created for the two plate parallel weld configuration calculator.
Stress created for the two plate perpendicular weld configuration.
Open: Stress created for the two plate perpendicular weld configuration Calculator.
Stress created for the lap plate perpendicular weld configuration.
Open: Stress lap plate perpendicular weld configuration calculator.
Three Lap Plate Weld Axial Load Parallel Weld Stress Equations and Calculator
Open: Three Lap Plate Weld Axial Load Parallel Weld Stress Calculator
Plate
Plate "L" Section Weld Stress Calculator
Open: Plate "L" Section Weld Stress Calculator
Weld Shear Stress for Applied Torque on Solid Shaft Equations and Calculator
Open: Weld Shear Stress for Applied Torque on Solid Shaft Calculator
Weld Shear Stress for Applied Bending Moment on Solid Shaft Equation and Calculator
Open: Weld Shear Stress for Applied Bending Moment on Solid Shaft Calculator
Weld Shear Stress for Applied Bending Moment on Rectanguler/Square Shaft Equation and Calculator
Open: Weld Shear Stress for Applied Bending Moment on Rectanguler/Square Shaft Calculator
Weld Shear Stress for Applied Bending Moment on Rectanguler Beam Equation and Calculator
Open: Weld Shear Stress for Applied Bending Moment on Rectanguler Beam Calculator
Weld Shear Stress for Applied Bending Force on Rectanguler Beam Equation and Calculator
Open: Weld Shear Stress for Applied Bending Force on Rectanguler Beam Calculator
Weld Stress for Bending Moment Applied Rectangular Beam Equation and Calculator
Open: Weld Stress for Bending Moment Applied Rectangular Beam Calculator
Weld Stress for Load Applied to Rectangular Beam Equation and Calculator.
Open: Weld Stress for Load Applied to Rectangular Beam Calculator.
Weld Stress for Moment Applied to Rectangular Beam Equation and Calculator.
Open: Weld Stress for Moment Applied to Rectangular Beam Calculator
Weld Stress for Moment Applied to Rectangular Beam Calculator.
Open: Weld Stress for Moment Applied to Rectangular Beam Calculator.
Weld Stress for Bending Moment Applied to Rectangular Beam Equation and Calculator
Open: Weld Stress for Bending Moment Applied to Rectangular Beam Calculator
Weld Stress for Splice Plate Beam Equation and Calculator
Open: Weld Stress for Splice Plate Beam Calculator
Source: Welding Handbook, 3rd Edition, American Welding Society, 1950
Contribute Article
