Bending, Deflection and Stress Equations Calculator for Simply Supported on Both Ends Under Superimposed Loading
Structural Beam Deflection, Stress, Bending Equations and calculator for a Simply Supported Beam on Both Ends Under Superimposed Loading Equations.
Beams of Uniform Cross Section, Loaded Transversely
Open
Beam Deflection and Stress Beams of Uniform Cross Section Calculator
Click on Images to view Large Readable Size
Structural Beam Deflection, Stress Formula
E =
Beam Modulus of Elasticity psi
(N/mm2)
I =
Beam Moment of Inertia in4 (mm4)
F =
 Loading Point lbs (N)
Mn = Beam Moment Calculated psi-in (N-mm)
WL
Distributed Load Amplitude Lbs/in2 (N/mm)
Wa
y =
Beam Deflection inches (mm)
an =
Some distance as indicated inches (mm)
  1. Roark's Stress & Strain
