Bearing Engineering and Knowledge Application Menu
Engineering Application & Design
  • The following are to links to Bearings editorials and engineering data.
  • Should you find any errors omissions broken links, please let us know
  • Do you want to contribute to this section? See Premium Publisher Program
** Search this PAGE ONLY, click on Magnifying Glass **
A bearing is a machine element that constrains relative motion and reduces friction between moving parts to only the desired motion. The design of the bearing may, for example, provide for free linear movement of the moving part or for free rotation around a fixed axis; or, it may prevent a motion by controlling the vectors of normal forces that bear on the moving parts. Many bearings also facilitate the desired motion as much as possible, such as by minimizing friction. Bearings are classified broadly according to the type of operation, the motions allowed, or to the directions of the loads (forces) applied to the parts.
