Beam Deflection and Stress Equations Calculator for Fixed at Both Ends, Load at any location Beam
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends, Load at any location.
Beam Moment and Loads at Supports
M = Wab2 / l2
W1=(Wb2 / l3))(l + 2a)
Open: Moment and Loads at Supports Calculator
Beam Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
Beam Stress For segment length a,
General Stress at any Given Point
Beam Stress For segment length b
Open:Stress for Segment a and b Calculator
Beam Stress at Critical Locations Points
Beam Stress at end nearest to segment of length a,
Stress at Critical Locations/Points
Beam Stress at end nearest to segment of length b,
Open:Stress at end nearest a or b Calculator
Maximum Beam stress is at end nearest to shorter segment.
Beam Stress is zero at
Maximum stress is at end nearest to shorter segment.
and
Stress is zero at
Greatest negative Beam stress, at load
Greatest negative stress, at load
Open:Greatest negative stress at load Calculator
Beam Deflection at any Point
For length a,
For length b
Open: Deflection at any point Length a or b Calculator
Critical Beam Deflections
Beam Deflection at load
Deflection at load
Open: Deflection at Load Calculator
If b length is the longer segment and a is the shorter one.
The maximum Beam deflection is in the longer segment:
maximum deflection is in the longer segment
and
E = Beam Modulus of Elasticity psi
(N/mm2)
I = Beam Moment of Inertia in4 (mm4)
W = Beam  Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
a, b = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition
  • Machinery's Handbook, 23st Edition
  • Machinery's Handbook, 27st Edition
