Beam Deflection Calculator and Stress Equations for Fixed at Both Ends with Uniform Loading
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends with Uniform Loading.
Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Stress at any Given Point
Open: Stress at Given Point x Calculator
Stress at Critical Locations/Points
Maximum Stress (at fixed ends)
The greatest negative stress (at center)
Open: Maximum Stress and Negative Stress Calculator
Stress is zero at: x = 0.7887l and x = 0.2113l
Deflection at any Point
Open: Deflection at any Point Calculator
Critical Deflections
Maximum Deflection (Center of Beam)
Open: Deflection Maximum Calculator
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
u = Some distance as indicated inches (mm)
a, b = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition
  • Machinery's Handbook, 23st Edition
  • Machinery's Handbook, 27st Edition
