Beam Deflection Calculator and Stress Equations for Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads
Structural Beam Deflection, Stress, Bending Equations and calculator for a Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads.
R1 = Load Left Point
R2 = Load Right Point
R = Load Center
Open: Load at R1, R2, and R Calculator
Beam Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
General Stress at any Given Point
Open: Stress at any Given Point Calculator
Beam Stress at Critical Locations/Points
Open: Stress at Critical Points Calculator
Beam Deflection at any Point
Open: Deflection at Defined Points Calculator
E = Modulus of Elasticity psi
(N/mm2)
I = Area Moment of Inertia in4 (mm4)
W =   Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
a, b = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l " (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition
  • Machinery's Handbook, 23st Edition
  • Machinery's Handbook, 27st Edition
