Capillary Number and Pressure Formulas and Calculators
Civil Engineering Design and Engineering
Fluids Engineering and Design
The capillary number (Nc) is a dimensionless quantity representing the relative effect of viscous drag forces versus surface tension forces acting across an interface between a liquid and a gas, or between two immiscible liquids.
Free (Basic) Membership minimum is required to use this calculator
Nc = µw V / σow
µw = Viscosity of Displacing Fluid (cP)
V = Characteristic Velocity (ft/D)
σow = Surface or Interfacial Tension of Oil and Water Phases (dyn/cm)
Nc
= Capillary Number (dimensionless)
cP = centipose
Capillary pressure formula
Pc = 2 σ cos(θ) / r
σ = Fluid interfacial Tension (dyn/cm)
θ
= Angle of Wettability (degree)
r
= Radius of Capillary (cm)
Pc =
Capillary Pressure (dyn/cm)
Wikipedia
