Spring Shear Stress Calculator
Spring Design and Engineering
Shear Stress Helical Linear Spring Calculator
This calculator will determine the shear stress in a helical spring as well as maximum allowable torsional stress
shear stress in a helical linear spring
τ = Ks 8 F D / ( π d3 )
where
d = wire diameter, (in, mm)
F = applied force, (lbs, N)
D = mean spring diameter, (in, mm)
Ks = (2C + 1)/(2C),
C = D/d.
The deflection and force are related by F = kx where the spring rate (spring constant) k is given by
k = d4 G / ( 8 D3 N )
where
G = shear modulus of elasticity, (N/mm2, lbs/in2)
N = number of active coils, #
Spring Material: The minimum tensile strength of common spring steels may be determined from
Eq. 3
Sut = A / dm
where
Sut = tensile strength in MPa,
d = wire diameter in millimeters,
A and m are listed in the table
Material
ASTM
m
A
Music wire
A228
0.163
2060
Oil-tempered wire
A229
0.193
1610
Hard-drawn wire
A227
0.201
1510
Chrome vanadium
A232
0.155
1790
Chrome silicon
A401
0.091
1960
Maximum allowable torsional stress for static applications may be approximated as
Ssy = τ = 0.45 Sut cold-drawn carbon steel (A227, A228, A229)
Ssy = τ = 0.50 Sut hardened and tempered carbon and low-alloy steel (A232, A401)
Source
Fundamentals of Engineering Supplied Reference Handbook, Fifth Edition
National Council of Examiners for Engineering and Surveying
