Related Resources: spring material
Axial Tension Compression Spring Stiffness Constant Equations and Calculator
Spring Design and Engineering
Vibration Engineering and Design
Axial Tension or Compression Springs Stiffness Constant Equations and Calculator
k = ( G d2 ) / ( 8 n D3)
k = Spring Stiffness (lb/in)
d = Wire Diameter (in),
D = Mean Coil Diameter (in),
n = Number of Active Coils,
G = Modulus of Elasticty in Shear (lb/in2)
Reference Harris, Shock and Vibration Handbook
