Spring Design Menu | Spring Suppliers and Manufacturers
This calculator will determine the spring rate constant related to a compression spring from basic geometry and material data input. Default units are shown in inches, etc however SI (metric) can be used.
This equation will determine (estimate) the
Spring Rate (k) of a compression spring. Spring rate is best
determined by test and measurement techniques.
Open Compression Spring Constant (k) Calculator
Equation:
k = Gd4/[8nD3]
k = constant, pounds of load per inch of deflection
G = modulus of rigidity
of spring material, pounds per square inch
d = wire diameter, inches
n = number of active coils, which is the number of coils subjected to flexure (always less than the total number of coils)
D = mean coil diameter, inches = Outer Diameter - Wire Diameter
G is calculated from the spring materials Elastic modulus and Poisson Ratio n
G = E/(2(1 + v)
The pitch of the spring coil can be found by
Cp = Lf / nc
Lf = Uncompressed length of spring
nc = Number of coils
The angle of the spring coil relativeto the mounting base is found:
f = atan [
Cp / p D ]
Compression Spring Design Suggestions
