API Casing Data Tables Size 7.625 - 8.625
Fluid Flow Table of Contents
API Casing Data Tables Size 7.625 - 8.625.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal Weight
T & C
Grade
Collapse
Pressure
(psi)
Internal Yield Pressure
Minimum Yield (psi)
PE
STC
LTC
BTC
7.625
45.30
T-95
13660
12970
12460
11620
7.625
45.30
H2S-95
13660
12970
12460
11620
7.625
45.30
C-95
13660
12970
12460
11620
7.625
45.30
P-110
15430
15020
14430
13460
7.625
45.30
Q-125
17090
17070
16400
15290
7.625
45.30
V-150
19660
20480
19680
18350
7.625
47.10
L-80
12040
11480
10490
9790
7.625
47.10
N-80
12040
11480
10490
9790
7.625
47.10
C-90
13540
12910
11810
11010
7.625
47.10
T-95
14300
13630
12460
11620
7.625
47.10
C-95
14300
13630
12460
11620
7.625
47.10
P-110
16550
15780
14430
13460
7.625
47.10
Q-125
18700
17930
16400
15290
7.625
51.20
C-90
14760
14190
7.625
51.20
T-95
15580
14980
7.625
55.30
C-90
15960
15490
7.625
55.30
T-95
16850
16350
7.750
46.10
L-80
11340
10750
10490
9790
7.750
46.10
HCL-80
13320
10750
10490
9790
7.750
46.10
C-90
12740
12090
11810
11010
7.750
46.10
H2S-90
12740
12090
11810
11010
7.750
46.10
S-95
13320
12760
12460
11620
7.750
46.10
T-95
13320
12760
12460
11620
7.750
46.10
H2S-95
13320
12760
12460
11620
7.750
46.10
C-95
13320
12760
12460
11620
7.750
46.10
P-110
14990
14780
14430
13460
7.750
46.10
Q-125
16580
16790
16400
15290
7.750
46.10
LS-140
18090
18810
18360
17130
8.625
24.00
J-55
1370
2950
2950
8.625
24.00
K-55
1370
2950
2950
8.625
24.00
HCK-55
1780
2950
2950
8.625
24.00
LS-65
1430
3480
3480
8.625
28.00
H-40
1610
2470
2470
8.625
28.00
HCK-55
2680
3390
3390
3390
3390
8.625
32.00
H-40
2200
2860
2860
8.625
32.00
J-55
2530
3930
3930
3930
3930
8.625
32.00
K-55
2530
3930
3930
3930
3930
8.625
32.00
HCK-55
4130
3930
3930
3930
3930
8.625
32.00
LS-65
2740
4640
4640
4640
4640
8.625
36.00
J-55
3450
4460
4460
4460
4460
8.625
36.00
K-55
3450
4460
4460
4460
4460
8.625
36.00
HCK-55
5300
4460
4460
4460
4460
8.625
36.00
LS-65
3760
5280
5280
5280
5280
8.625
36.00
L-80
4100
6490
6490
6490
8.625
36.00
HCL-80
6060
6490
6490
6490
8.625
36.00
N-80
4100
6490
6490
6490
8.625
36.00
HCN-80
6060
6490
6490
6490
8.625
40.00
LS-65
4890
5930
5930
5930
8.625
40.00
L-80
5520
7300
7300
7300
8.625
40.00
HCL-80
7900
7300
7300
7300
8.625
40.00
N-80
5520
7300
7300
7300
8.625
40.00
HCN-80
7900
7300
7300
7300
8.625
40.00
C-90
5870
8220
8220
8220
8.625
40.00
H2S-90
7900
8220
8220
8220
8.625
40.00
S-95
7900
8670
8670
8670
8.625
40.00
T-95
6020
8670
8670
8670
8.625
40.00
H2S-95
7900
8670
8670
8670
8.625
40.00
C-95
6020
8670
8670
8670
8.625
40.00
HCP-110
7900
10040
10040
10040
8.625
40.00
P-110
6390
10040
10040
10040
8.625
49.00
L-80
8580
9040
9040
9040
8.625
49.00
HCL-80
10400
9040
9040
9040
8.625
49.00
N-80
8580
9040
9040
9040
8.625
49.00
HCN-80
10400
9040
9040
9040
O.D.
(inch)
Nominal Weight
T & C
Grade
Joint Strength
1000 lbs
Body Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
STC
LTC
BTC
API
LSS
7.625
45.30
T-95
1101
1251
1248
0.595
6.435
6.310
7.625
45.30
H2S-95
1101
1251
1248
0.595
6.435
6.310
7.625
45.30
C-95
1101
1251
1248
0.595
6.435
6.310
7.625
45.30
P-110
1285
1477
1446
0.595
6.435
6.310
7.625
45.30
Q-125
1439
1619
1643
0.595
6.435
6.310
7.625
45.30
V-150
1721
1926
1971
0.595
6.435
6.310
7.625
47.10
L-80
997
1160
1100
0.625
6.375
6.250
7.625
47.10
N-80
1013
1205
1100
0.625
6.375
6.250
7.625
47.10
C-90
1100
1238
1237
0.625
6.375
6.250
7.625
47.10
T-95
1159
1300
1306
0.625
6.375
6.250
7.625
47.10
C-95
1159
1300
1306
0.625
6.375
6.250
7.625
47.10
P-110
1353
1545
1512
0.625
6.375
6.250
7.625
47.10
Q-125
1515
1672
1718
0.625
6.375
6.250
7.625
51.20
C-90
1348
0.687
6.251
6.126
7.625
51.20
T-95
1423
0.687
6.251
6.126
7.625
55.30
C-90
1458
0.750
6.125
6.000
7.625
55.30
T-95
1539
0.750
6.125
6.000
7.750
46.10
L-80
841
1001
1070
0.595
6.560
6.435
6.500
7.750
46.10
HCL-80
965
1091
1070
0.595
6.560
6.435
6.500
7.750
46.10
C-90
928
1074
1204
0.595
6.560
6.435
6.500
7.750
46.10
H2S-90
965
1091
1204
0.595
6.560
6.435
6.500
7.750
46.10
S-95
992
1168
1271
0.595
6.560
6.435
6.500
7.750
46.10
T-95
978
1129
1271
0.595
6.560
6.435
6.500
7.750
46.10
H2S-95
978
1129
1271
0.595
6.560
6.435
6.500
7.750
46.10
C-95
978
1129
1271
0.595
6.560
6.435
6.500
7.750
46.10
P-110
1142
1334
1471
0.595
6.560
6.435
6.500
7.750
46.10
Q-125
1279
1462
1672
0.595
6.560
6.435
6.500
7.750
46.10
LS-140
1429
1628
1872
0.595
6.560
6.435
6.500
8.625
24.00
J-55
244
381
0.264
8.097
7.972
8.625
24.00
K-55
263
381
0.264
8.097
7.972
8.625
24.00
HCK-55
326
381
0.264
8.097
7.972
8.625
24.00
LS-65
302
451
0.264
8.097
7.972
8.625
28.00
H-40
233
318
0.304
8.017
7.892
8.625
28.00
HCK-55
414
464
651
437
0.304
8.017
7.892
8.625
32.00
H-40
279
366
0.352
7.921
7.796
7.875
8.625
32.00
J-55
372
417
579
503
0.352
7.921
7.796
7.875
8.625
32.00
K-55
402
452
690
503
0.352
7.921
7.796
7.875
8.625
32.00
HCK-55
497
556
749
503
0.352
7.921
7.796
7.875
8.625
32.00
LS-65
435
487
664
595
0.352
7.921
7.796
7.875
8.625
36.00
J-55
434
486
654
568
0.400
7.825
7.700
8.625
36.00
K-55
468
526
780
568
0.400
7.825
7.700
8.625
36.00
HCK-55
579
648
847
568
0.400
7.825
7.700
8.625
36.00
LS-65
506
567
751
672
0.400
7.825
7.700
8.625
36.00
L-80
678
864
827
0.400
7.825
7.700
8.625
36.00
HCL-80
779
945
827
0.400
7.825
7.700
8.625
36.00
N-80
688
895
827
0.400
7.825
7.700
8.625
36.00
HCN-80
779
945
827
0.400
7.825
7.700
8.625
40.00
LS-65
649
839
751
0.450
7.725
7.600
7.625
8.625
40.00
L-80
776
966
925
0.450
7.725
7.600
7.625
8.625
40.00
HCL-80
892
1057
925
0.450
7.725
7.600
7.625
8.625
40.00
N-80
788
1001
925
0.450
7.725
7.600
7.625
8.625
40.00
HCN-80
892
1057
925
0.450
7.725
7.600
7.625
8.625
40.00
C-90
858
1038
1040
0.450
7.725
7.600
7.625
8.625
40.00
H2S-90
892
1057
1040
0.450
7.725
7.600
7.625
8.625
40.00
S-95
915
1127
1098
0.450
7.725
7.600
7.625
8.625
40.00
T-95
904
1092
1098
0.450
7.725
7.600
7.625
8.625
40.00
H2S-95
904
1092
1098
0.450
7.725
7.600
7.625
8.625
40.00
C-95
904
1092
1098
0.450
7.725
7.600
7.625
8.625
40.00
HCP-110
1055
1228
1271
0.450
7.725
7.600
7.625
8.625
40.00
P-110
1055
1228
1271
0.450
7.725
7.600
7.625
8.625
49.00
L-80
983
1180
1129
0.557
7.511
7.386
8.625
49.00
HCL-80
1129
1291
1129
0.557
7.511
7.386
8.625
49.00
N-80
997
1222
1129
0.557
7.511
7.386
8.625
49.00
HCN-80
1129
1291
1129
0.557
7.511
7.386
Related Resources:
