API Casing Data Tables Size 7.625
API Casing Data Tables Size 7.625.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal Weight
T & C
Grade
Collapse
Pressure
(psi)
Internal Yield Pressure
Minimum Yield
(psi)
Joint Strength
1000 lbs
Body Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
PE
STC
LTC
BTC
STC
LTC
BTC
API
LSS
7.625
26.40
HCN-80
4850
6020
6020
6020
553
691
602
0.328
6.969
6.844
7.625
26.40
C-90
3610
6780
6780
6780
532
681
677
0.328
6.969
6.844
7.625
26.40
H2S-90
4850
6780
6780
6780
553
691
677
0.328
6.969
6.844
7.625
26.40
S-95
4850
7150
7150
7150
568
740
714
0.328
6.969
6.844
7.625
26.40
T-95
3710
7150
7150
7050
560
716
714
0.328
6.969
6.844
7.625
26.40
H2S-95
4850
7150
7150
7050
560
716
714
0.328
6.969
6.844
7.625
26.40
C-95
3710
7150
7150
7150
560
716
714
0.328
6.969
6.844
7.625
26.40
HCP-110
4850
8280
8280
8280
654
845
827
0.328
6.969
6.844
7.625
26.40
P-110
3920
8280
8280
8280
654
845
827
0.328
6.969
6.844
7.625
29.70
LS-65
4310
5590
5590
5590
474
629
555
0.375
6.875
6.750
7.625
29.70
L-80
4790
6890
6890
6890
566
721
683
0.375
6.875
6.750
7.625
29.70
HCL-80
7150
6890
6890
6890
650
785
683
0.375
6.875
6.750
7.625
29.70
N-80
4790
6890
6890
6890
575
749
683
0.375
6.875
6.750
7.625
29.70
HCN-80
7150
6890
6890
6890
650
785
683
0.375
6.875
6.750
7.625
29.70
C-90
5040
7750
7750
7750
625
773
769
0.375
6.875
6.750
7.625
29.70
H2S-90
7150
7750
7750
7750
650
785
769
0.375
6.875
6.750
7.625
29.70
S-95
7150
8180
8180
8180
668
841
811
0.375
6.875
6.750
7.625
29.70
T-95
5140
8180
8180
8180
659
813
811
0.375
6.875
6.750
7.625
29.70
H2S-95
7150
8180
8180
8180
659
813
811
0.375
6.875
6.750
7.625
29.70
C-95
5140
8180
8180
8180
659
813
811
0.375
6.875
6.750
7.625
29.70
HCP-110
7150
9470
9470
9470
769
960
940
0.375
6.875
6.750
7.625
29.70
P-110
5350
9470
9470
9470
769
960
940
0.375
6.875
6.750
7.625
33.70
L-80
6560
7900
7900
7900
664
820
778
0.430
6.765
6.640
7.625
33.70
HCL-80
8800
7900
7900
7900
762
894
778
0.430
6.765
6.640
7.625
33.70
N-80
6560
7900
7900
7900
674
852
778
0.430
6.765
6.640
7.625
33.70
HCN-80
8800
7900
7900
7900
762
894
778
0.430
6.765
6.640
7.625
33.70
C-90
7050
8880
8880
8880
733
880
875
0.430
6.765
6.640
7.625
33.70
H2S-90
8800
8880
8880
8880
762
894
875
0.430
6.765
6.640
7.625
33.70
S-95
8800
9380
9380
9380
783
957
923
0.430
6.765
6.640
7.625
33.70
T-95
7280
9380
9380
9380
772
925
923
0.430
6.765
6.640
7.625
33.70
H2S-95
8800
9380
9380
9380
772
925
923
0.430
6.765
6.640
7.625
33.70
C-95
7280
9380
9380
9380
772
925
923
0.430
6.765
6.640
7.625
33.70
HCP-110
8800
10860
10860
10860
901
1093
1069
0.430
6.765
6.640
7.625
33.70
P-110
7870
10860
10860
10860
901
1093
1069
0.430
6.765
6.640
7.625
33.70
HCQ-125
8800
12340
12340
12340
1009
1197
1215
0.430
6.765
6.640
7.625
33.70
Q-125
8350
12340
12340
12340
1009
1197
1215
0.430
6.765
6.640
7.625
33.70
LS-140
8690
13820
13820
13820
1128
1334
1361
0.430
6.765
6.640
7.625
33.70
V-150
8850
14800
14800
14800
1207
1424
1458
0.430
6.765
6.640
7.625
39.00
L-80
8820
9180
9180
9180
786
945
895
0.500
6.625
6.500
7.625
39.00
HCL-80
10600
9180
9180
9180
901
1029
895
0.500
6.625
6.500
7.625
39.00
N-80
8820
9180
9180
9180
798
981
895
0.500
6.625
6.500
7.625
39.00
HCN-80
10600
9180
9180
9180
901
1029
895
0.500
6.625
6.500
7.625
39.00
C-90
9620
10330
10330
10330
867
1013
1007
0.500
6.625
6.500
7.625
39.00
H2S-90
10600
10330
10330
10330
901
1029
1007
0.500
6.625
6.500
7.625
39.00
S-95
10600
10900
10900
10900
926
1101
1063
0.500
6.625
6.500
7.625
39.00
T-95
10000
10900
10900
10900
914
1065
1063
0.500
6.625
6.500
7.625
39.00
H2S-95
10600
10900
10900
10900
914
1065
1063
0.500
6.625
6.500
7.625
39.00
C-95
10000
10900
10900
10900
914
1065
1063
0.500
6.625
6.500
7.625
39.00
P-110
11080
12620
12620
12620
1066
1258
1231
0.500
6.625
6.500
7.625
39.00
Q-125
12060
14340
14340
14340
1194
1379
1399
0.500
6.625
6.500
7.625
39.00
LS-140
12930
16070
16070
16070
1335
1536
1567
0.500
6.625
6.500
7.625
39.00
V-150
13440
17210
17210
17210
1428
1640
1679
0.500
6.625
6.500
7.625
42.80
L-80
10810
10320
10320
9790
891
1053
998
0.562
6.501
6.376
7.625
42.80
N-80
10810
10320
10320
9790
905
1093
998
0.562
6.501
6.376
7.625
42.80
C-90
11890
11610
11610
11010
983
1129
1122
0.562
6.501
6.376
7.625
42.80
T-95
12410
12250
12250
11620
1037
1187
1185
0.562
6.501
6.376
7.625
42.80
C-95
12410
12250
12250
11620
1037
1187
1185
0.562
6.501
6.376
7.625
42.80
P-110
13920
14190
14190
13460
1210
1402
1372
0.562
6.501
6.376
7.625
42.80
Q-125
15350
16120
16120
15290
1355
1536
1559
0.562
6.501
6.376
7.625
45.30
L-80
11510
10920
10490
9790
947
1109
1051
0.595
6.435
6.310
7.625
45.30
HCL-80
12900
10920
10490
9790
1086
1177
1051
0.595
6.435
6.310
7.625
45.30
N-80
11510
10920
10490
9790
962
1152
1051
0.595
6.435
6.310
7.625
45.30
HCN-80
12900
10920
10490
9790
1086
1208
1051
0.595
6.435
6.310
7.625
45.30
C-90
12950
12290
11810
11010
1045
1189
1183
0.595
6.435
6.310
7.625
45.30
H2S-90
12950
12290
11810
11010
1086
1208
1183
0.595
6.435
6.310
7.625
45.30
S-95
13660
12970
12460
11620
1116
1293
1248
0.595
6.435
6.310
Related Resources:
