API Casing Data Tables sizes 7.000 - 7.625
API Casing Data Tables Sizes 7.000 - 7.625.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal
Weight
T & C
Grade
Collapse Pressure
(psi)
Internal Yield Pressure
Minimum Yield (psi)
Joint Strength
1000 lbs
Body
Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
PE
STC
LTC
BTC
STC
LTC
BTC
API
LSS
7.000
32.00
HCL-80
10400
9060
9060
8460
738
832
745
0.453
6.094
5.969
6.000
7.000
32.00
N-80
8610
9060
9060
8460
672
823
745
0.453
6.094
5.969
6.000
7.000
32.00
HCN-80
10400
9060
9060
8460
738
860
745
0.453
6.094
5.969
6.000
7.000
32.00
C-90
9380
10190
10190
9520
729
847
839
0.453
6.094
5.969
6.000
7.000
32.00
H2S-90
10400
10190
10190
9520
738
860
839
0.453
6.094
5.969
6.000
7.000
32.00
S-95
10400
10760
10760
10050
779
922
885
0.453
6.094
5.969
6.000
7.000
32.00
T-95
9750
10760
10760
10050
768
891
885
0.453
6.094
5.969
6.000
7.000
32.00
H2S-95
10400
10760
10760
10050
768
891
885
0.453
6.094
5.969
6.000
7.000
32.00
C-95
9750
10760
10760
10050
768
891
885
0.453
6.094
5.969
6.000
7.000
32.00
P-110
10780
12460
12460
11640
897
1053
1025
0.453
6.094
5.969
6.000
7.000
32.00
Q-125
11720
14160
14160
13220
996
1152
1165
0.453
6.094
5.969
6.000
7.000
32.00
LS-140
12540
15850
15850
14810
1107
1283
1304
0.453
6.094
5.969
6.000
7.000
32.00
V-150
13020
16990
16990
15870
1180
1370
1398
0.453
6.094
5.969
6.000
7.000
35.00
L-80
10180
9960
9240
8460
734
833
814
0.498
6.004
5.879
7.000
35.00
HCL-80
11600
9960
9240
8460
819
832
814
0.498
6.004
5.879
7.000
35.00
N-80
10180
9960
9240
8460
746
876
814
0.498
6.004
5.879
7.000
35.00
HCN-80
11600
9960
9240
8460
819
876
814
0.498
6.004
5.879
7.000
35.00
C-90
11170
11210
10390
9520
809
876
915
0.498
6.004
5.879
7.000
35.00
H2S-90
11600
11210
10390
9520
819
876
915
0.498
6.004
5.879
7.000
35.00
S-95
11650
11830
10970
10050
865
964
966
0.498
6.004
5.879
7.000
35.00
T-95
11650
11830
10970
10050
853
920
966
0.498
6.004
5.879
7.000
35.00
H2S-95
11650
11830
10970
10050
853
920
966
0.498
6.004
5.879
7.000
35.00
C-95
11650
11830
10970
10050
853
920
966
0.498
6.004
5.879
7.000
35.00
P-110
13020
13700
12700
11640
996
1096
1119
0.498
6.004
5.879
7.000
35.00
Q-125
14310
15560
14430
13220
1106
1183
1272
0.498
6.004
5.879
7.000
35.00
LS-140
15490
17430
16170
14810
1229
1315
1424
0.498
6.004
5.879
7.000
35.00
V-150
16220
18680
17320
15870
1311
1402
1526
0.498
6.004
5.879
7.000
38.00
L-80
11390
10800
9240
8460
801
832
877
0.540
5.920
5.795
7.000
38.00
HCL-80
12700
10800
9240
8460
831
832
877
0.540
5.920
5.795
7.000
38.00
N-80
11390
10800
9240
8460
814
876
877
0.540
5.920
5.795
7.000
38.00
HCN-80
12700
10800
9240
8460
831
876
877
0.540
5.920
5.795
7.000
38.00
C-90
12820
12150
10390
9520
883
876
986
0.540
5.920
5.795
7.000
38.00
H2S-90
12820
12150
10390
9520
883
876
986
0.540
5.920
5.795
7.000
38.00
S-95
13440
12830
10970
10050
944
964
1041
0.540
5.920
5.795
7.000
38.00
T-95
13440
12830
10970
10050
931
920
1041
0.540
5.920
5.795
7.000
38.00
H2S-95
13440
12830
10970
10050
931
920
1041
0.540
5.920
5.795
7.000
38.00
C-95
13440
12830
10970
10050
931
920
1041
0.540
5.920
5.795
7.000
38.00
P-110
15140
14850
12700
11640
1087
1096
1205
0.540
5.920
5.795
7.000
38.00
Q-125
16750
16880
14430
13220
1207
1183
1370
0.540
5.920
5.795
7.000
38.00
LS-140
18280
18900
16170
14810
1341
1315
1534
0.540
5.920
5.795
7.000
38.00
V-150
19240
20250
17320
15870
1430
1402
1644
0.540
5.920
5.795
7.000
41.00
C-90
13900
13280
10390
9520
903
876
1069
0.590
5.820
5.695
7.000
41.00
H2S-90
13900
13280
10390
9520
903
876
1069
0.590
5.820
5.695
7.000
41.00
T-95
14670
14010
10970
10050
952
920
1129
0.590
5.820
5.695
7.000
41.00
H2S-95
14670
14010
10970
10050
950
920
1129
0.590
5.820
5.695
7.000
41.00
P-110
16990
16230
12700
11640
1111
1096
1307
0.590
5.820
5.695
7.000
41.00
Q-125
19300
18440
14430
13220
1244
1183
1485
0.590
5.820
5.695
7.000
41.00
V-150
22820
22130
17320
15870
1488
1402
1782
0.590
5.820
5.695
7.000
42.70
C-90
14640
14060
1127
0.625
5.750
5.625
7.000
42.70
T-95
15450
14840
1189
0.625
5.750
5.625
7.000
46.40
C-90
15930
15460
1226
0.687
5.626
5.500
7.000
46.40
T-95
16820
16320
1294
0.687
5.626
5.500
7.000
50.10
C-90
17220
16880
1325
0.750
5.500
5.375
7.000
50.10
T-95
18810
17810
1399
0.750
5.500
5.375
7.000
53.60
C-90
18460
18270
1421
0.812
5.376
5.251
7.000
53.60
T-95
19480
19290
1500
0.812
5.376
5.251
7.000
57.10
C-90
19690
19690
1515
0.875
5.250
5.125
7.000
57.10
T-95
20780
20780
1600
0.875
5.250
5.125
7.625
24.00
H-40
2030
2750
2750
212
276
0.300
7.025
6.900
7.625
26.40
J-55
2890
4140
4140
4140
4140
315
346
483
414
0.328
6.969
6.844
7.625
26.40
K-55
2890
4140
4140
4140
4140
342
377
581
414
0.328
6.969
6.844
7.625
26.40
LS-65
3100
4890
4890
4890
4890
368
403
554
489
0.328
6.969
6.844
7.625
26.40
L-80
3400
6020
6020
6020
482
635
602
0.328
6.969
6.844
7.625
26.40
HCL-80
4850
6020
6020
6020
533
691
602
0.328
6.969
6.844
7.625
26.40
N-80
3400
6020
6020
6020
490
659
602
0.328
6.969
6.844
Related Resources
