API Casing Data Tables Size 10.750 - 11.750
API Casing Data Tables Size 10.750 - 11.750.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal
Weight
T & C
Grade
Collapse
Pressure
(psi)
Internal Yield Pressure
Minimum Yield (psi)
Joint Strength
1000 lbs
Body
Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
PE
STC
LTC
BTC
STC
LTC
BTC
API
LSS
10.750
65.70
C-95
6960
9200
9200
9200
1263
1765
1803
0.595
9.560
9.404
9.504
10.750
65.70
HCP-110
8640
10650
10650
10650
1472
2077
2088
0.595
9.560
9.404
9.504
10.750
65.70
P-110
7500
10650
10650
10650
1472
2077
2088
0.595
9.560
9.404
9.504
10.750
65.70
HCQ-125
8640
12110
12110
12110
1653
2291
2373
0.595
9.560
9.404
9.504
10.750
65.70
Q-125
7920
12110
12110
12110
1653
2291
2373
0.595
9.560
9.404
9.504
10.750
65.70
LS-140
8640
13560
13560
13560
1848
2554
2657
0.595
9.560
9.404
9.504
10.750
65.70
V-150
8320
14530
14530
14530
1978
2730
2847
0.595
9.560
9.404
9.504
10.750
71.10
H2S-90
9300
9520
9200
8980
1317
1822
1856
0.650
9.450
9.294
10.750
71.10
S-95
9600
10050
9710
9480
1403
1971
1959
0.650
9.450
9.294
10.750
71.10
H2S-95
9600
10050
9710
9480
1388
1918
1959
0.650
9.450
9.294
10.750
71.10
HCP-110
9600
11640
11240
10980
1618
2257
2269
0.650
9.450
9.294
10.750
71.10
P-110
9300
11640
11240
10980
1618
2257
2269
0.650
9.450
9.294
10.750
71.10
Q-125
9990
13230
12780
12480
1817
2489
2578
0.650
9.450
9.294
10.750
71.10
LS-140
10570
14810
14310
13980
2031
2775
2888
0.650
9.450
9.294
10.750
71.10
V-150
10880
15870
15330
14970
2174
2966
3094
0.650
9.450
9.294
10.750
73.20
C-90
8760
9850
1915
0.672
9.406
9.250
10.750
73.20
T-95
9090
10390
2021
0.672
9.406
9.250
10.750
79.20
C-90
10370
10750
2079
0.734
9.282
9.126
10.750
79.20
T-95
10800
11350
2194
0.734
9.282
9.126
10.750
85.30
C-90
12010
11680
2243
0.797
9.156
9.000
10.750
85.30
T-95
12540
12330
2367
0.797
9.156
9.000
11.750
42.00
H-40
1040
1980
1980
1980
307
554
478
0.333
11.084
10.928
11.750
47.00
J-55
1510
3070
3070
3070
477
807
737
0.375
11.000
10.844
11.750
47.00
K-55
1510
3070
3070
3070
509
935
737
0.375
11.000
10.844
11.750
47.00
HCK-55
2000
3070
3070
3070
638
1054
737
0.375
11.000
10.844
11.750
47.00
LS-65
1590
3630
3630
3630
557
931
817
0.375
11.000
10.844
11.750
54.00
J-55
2070
3560
3560
3560
568
931
850
0.435
10.880
10.724
11.750
54.00
K-55
2070
3560
3560
3560
606
1079
850
0.435
10.880
10.724
11.750
54.00
HCK-55
3100
3560
3560
3560
760
1216
850
0.435
10.880
10.724
11.750
54.00
LS-65
2250
4210
4210
4210
665
1074
1005
0.435
10.880
10.724
11.750
60.00
J-55
2660
4010
4010
4010
649
1042
952
0.489
10.772
10.616
11.750
60.00
K-55
2660
4010
4010
4010
693
1208
952
0.489
10.772
10.616
11.750
60.00
HCK-55
4360
4010
4010
4010
869
1361
952
0.489
10.772
10.616
11.750
60.00
LS-65
2840
4730
4730
4730
759
1201
1125
0.489
10.772
10.616
11.750
60.00
L-80
3180
5830
5830
5830
913
1399
1384
0.489
10.772
10.616
11.750
60.00
HCL-80
4410
5830
5830
5830
1055
1555
1384
0.489
10.772
10.616
11.750
60.00
N-80
3180
5830
5830
5830
924
1440
1384
0.489
10.772
10.616
11.750
60.00
HCN-80
4410
5830
5830
5830
1055
1555
1384
0.489
10.772
10.616
11.750
60.00
C-90
3360
6550
6550
6550
1011
1517
1557
0.489
10.772
10.616
11.750
60.00
H2S-90
4410
6550
6550
6550
1055
1555
1557
0.489
10.772
10.616
11.750
60.00
S-95
4410
6920
6920
6920
1077
1638
1644
0.489
10.772
10.616
11.750
60.00
T-95
3440
6920
6920
6920
1066
1596
1644
0.489
10.772
10.616
11.750
60.00
H2S-95
4410
6920
6920
6920
1066
1596
1644
0.489
10.772
10.616
11.750
60.00
C-95
3440
6920
6920
6920
1066
1596
1644
0.489
10.772
10.616
11.750
60.00
HCP-110
4410
8010
8010
8010
1242
1877
1903
0.489
10.772
10.616
11.750
60.00
P-110
3610
8010
8010
8010
1242
1877
1903
0.489
10.772
10.616
11.750
60.00
HCQ-125
4410
9100
9100
9100
1396
2074
2163
0.489
10.772
10.616
11.750
60.00
Q-125
3680
9100
9100
9100
1396
2074
2163
0.489
10.772
10.616
11.750
65.00
LS-65
3580
5170
5170
5170
837
1307
1223
0.534
10.682
10.526
11.750
65.00
L-80
3870
6360
6360
6360
1007
1521
1505
0.534
10.682
10.526
11.750
65.00
HCL-80
5740
6360
6360
6360
1152
1691
1505
0.534
10.682
10.526
11.750
65.00
N-80
3870
6360
6360
6360
1019
1566
1505
0.534
10.682
10.526
11.750
65.00
HCN-80
5740
6360
6360
6360
1164
1691
1505
0.534
10.682
10.526
11.750
65.00
H2S-90
5140
7160
7160
7160
1164
1691
1639
0.534
10.682
10.526
11.750
65.00
S-95
5740
7560
7560
7560
1189
1781
1788
0.534
10.682
10.526
11.750
65.00
H2S-95
5740
7560
7560
7560
1177
1736
1788
0.534
10.682
10.526
11.750
65.00
HCP-110
5740
8750
8750
8750
1371
2041
2070
0.534
10.682
10.526
11.750
65.00
P-110
4480
8750
8750
8750
1371
2041
2070
0.534
10.682
10.526
11.750
65.00
HCQ-125
5740
9940
9940
9940
1540
2256
2352
0.534
10.682
10.526
11.750
65.00
Q-125
4690
9940
9940
9940
1540
2256
2352
0.534
10.682
10.526
11.750
65.00
LS-140
5740
11130
11130
11130
1722
2516
2634
0.534
10.682
10.526
11.750
71.00
H2S-90
7280
7800
7800
7800
1226
1790
1838
0.582
10.586
10.430
11.750
71.00
S-95
7280
8230
8230
8230
1306
1933
1940
0.582
10.586
10.430
11.750
71.00
H2S-95
7280
8230
8230
8230
1293
1884
1940
0.582
10.586
10.430
11.750
71.00
HCP-110
7280
9530
9530
9530
1506
2215
2246
0.582
10.586
10.430
Related Resources:
