API Casing Data Tables sizes 6.625 - 7.000
API Casing Data Tables Sizes 6.625 - 7.000 .
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D. (inch)
Nominal
Weight
T & C
Grade
Collapse
Pressure
(psi)
Internal Yield Pressure
Minimum Yield (psi)
Joint Strength
1000 lbs
Body Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
PE
STC
LTC
BTC
STC
LTC
BTC
API
LCC
6.625
24.00
N-80
5760
7440
7440
7440
481
615
555
0.352
5.921
5.796
6.625
24.00
C-90
6140
8370
8370
8370
520
633
624
0.352
5.921
5.796
6.625
24.00
C-95
6310
8830
8830
8830
546
665
659
0.352
5.921
5.796
6.625
24.00
P-110
6730
10230
10230
10230
641
786
763
0.352
5.921
5.796
6.625
28.00
LS-65
7010
7160
7160
7160
483
607
529
0.417
5.791
5.666
6.625
28.00
L-80
8170
8810
8810
8810
576
693
651
0.417
5.791
5.666
6.625
28.00
N-80
8170
8810
8810
8810
586
721
651
0.417
5.791
5.666
6.625
28.00
C-90
8880
9910
9910
9910
633
742
732
0.417
5.791
5.666
6.625
28.00
C-95
9220
10460
10460
10460
665
780
773
0.417
5.791
5.666
6.625
28.00
P-110
10160
12120
12120
12120
781
922
895
0.417
5.791
5.666
6.625
32.00
L-80
10320
10040
10040
9820
666
783
734
0.475
5.675
5.550
6.625
32.00
N-80
10320
10040
10040
9820
677
814
734
0.475
5.675
5.550
6.625
32.00
C-90
11330
11290
11290
11050
732
837
826
0.475
5.675
5.550
6.625
32.00
C-95
11810
11920
11920
11660
769
880
872
0.475
5.675
5.550
6.625
32.00
P-110
13220
13800
13800
13500
904
1040
1009
0.475
5.675
5.550
6.625
32.00
Q-125
14530
15680
15680
15340
989
1138
1147
0.475
5.675
5.550
7.000
20.00
H-40
1970
2720
2720
176
230
0.272
6.456
6.331
7.000
20.00
J-55
2270
3740
3740
3740
3740
234
257
373
316
0.272
6.456
6.331
7.000
20.00
K-55
2270
3740
3740
3740
3740
254
281
451
316
0.272
6.456
6.331
7.000
20.00
LS-65
2480
4420
4420
4420
4420
272
300
427
374
0.272
6.456
6.331
7.000
23.00
J-55
3270
4360
4360
4360
4360
284
313
432
366
0.317
6.366
6.241
6.250
7.000
23.00
K-55
3270
4360
4360
4360
4360
309
341
522
366
0.317
6.366
6.241
6.250
7.000
23.00
LS-65
3540
5150
5150
5150
5150
331
364
494
433
0.317
6.366
6.241
6.250
7.000
23.00
L-80
3830
6340
6340
6340
435
565
532
0.317
6.366
6.241
6.250
7.000
23.00
HCL-80
5650
6340
6340
6340
485
614
532
0.317
6.366
6.241
6.250
7.000
23.00
N-80
3830
6340
6340
6340
442
588
532
0.317
6.366
6.241
6.250
7.000
23.00
HCN-80
5650
6340
6340
6340
485
614
532
0.317
6.366
6.241
6.250
7.000
23.00
C-90
4030
7130
7130
7130
479
605
599
0.317
6.366
6.241
6.250
7.000
23.00
H2S-90
5650
7130
7130
7130
485
614
599
0.317
6.366
6.241
6.250
7.000
23.00
S-95
5650
7530
7530
7530
512
659
632
0.317
6.366
6.241
6.250
7.000
23.00
T-95
4140
7530
7530
7530
505
636
632
0.317
6.366
6.241
6.250
7.000
23.00
H2S-95
5650
7530
7530
7530
505
636
632
0.317
6.366
6.241
6.250
7.000
23.00
C-95
4140
7530
7530
7530
505
636
632
0.317
6.366
6.241
6.250
7.000
26.00
J-55
4320
4980
4980
4980
4980
334
367
490
415
0.362
6.276
6.151
7.000
26.00
K-55
4320
4980
4980
4980
4980
364
401
592
415
0.362
6.276
6.151
7.000
26.00
LS-65
4800
5880
5880
5880
5880
389
428
561
491
0.362
6.276
6.151
7.000
26.00
L-80
5410
7240
7240
7240
511
641
604
0.362
6.276
6.151
7.000
26.00
HCL-80
7800
7240
7240
7240
570
696
604
0.362
6.276
6.151
7.000
26.00
N-80
5410
7240
7240
7240
519
667
604
0.362
6.276
6.151
7.000
26.00
HCN-80
7800
7240
7240
7240
570
696
604
0.362
6.276
6.151
7.000
26.00
C-90
5740
8140
8140
8140
563
687
679
0.362
6.276
6.151
7.000
26.00
H2S-90
7800
8150
8150
8150
570
696
679
0.362
6.276
6.151
7.000
26.00
S-95
7800
8600
8600
8600
602
747
717
0.362
6.276
6.151
7.000
26.00
T-95
5880
8600
8600
8600
593
722
717
0.362
6.276
6.151
7.000
26.00
H2S-95
7800
8600
8600
8600
593
722
717
0.362
6.276
6.151
7.000
26.00
C-95
5880
8600
8600
8600
593
722
717
0.362
6.276
6.151
7.000
26.00
HCP-110
7800
9950
9950
9950
693
853
830
0.362
6.276
6.151
7.000
26.00
P-110
6230
9950
9950
9950
639
853
830
0.362
6.276
6.151
7.000
29.00
LS-65
6090
6630
6630
6630
492
628
549
0.408
6.184
6.059
7.000
29.00
L-80
7020
8160
8160
8160
587
718
676
0.408
6.184
6.059
7.000
29.00
HCL-80
9200
8160
8160
8160
655
780
676
0.408
6.184
6.059
7.000
29.00
N-80
7020
8160
8160
8160
597
746
676
0.408
6.184
6.059
7.000
29.00
HCN-80
9200
8160
8160
8160
655
780
676
0.408
6.184
6.059
7.000
29.00
C-90
7580
9180
9180
9180
648
768
760
0.408
6.184
6.059
7.000
29.00
H2S-90
9200
9180
9180
9180
655
780
760
0.408
6.184
6.059
7.000
29.00
S-95
9200
9690
9690
9690
692
836
803
0.408
6.184
6.059
7.000
29.00
T-95
7830
9690
9690
9690
683
808
803
0.408
6.184
6.059
7.000
29.00
H2S-95
9200
9690
9690
9690
683
8080
803
0.408
6.184
6.059
7.000
29.00
C-95
7830
9690
9690
9690
683
808
803
0.408
6.184
6.059
7.000
29.00
HCP-110
9200
11220
11220
11220
797
955
929
0.408
6.184
6.059
7.000
29.00
P-110
8530
11220
11220
11220
797
955
929
0.408
6.184
6.059
7.000
29.00
HCQ-125
9200
12750
12750
12750
885
1045
1056
0.408
6.184
6.059
7.000
29.00
Q-125
9100
12750
12750
12750
885
1045
1056
0.408
6.184
6.059
7.000
29.00
V-150
9790
15300
15300
15300
1049
1243
1267
0.408
6.184
6.059
7.000
32.00
L-80
8610
9060
9060
8460
661
791
745
0.453
6.094
5.969
6.000
RelatedRelated Resources
