API Pipe Casing Data Tables Size 11.750 - 13.375
Fluid Flow Table of Contents
Pipe API Casing Data Tables Size 11.750 - 13.375.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D. (inch)
Nominal Weight T & C
Grade
Collapse Pressure (psi)
Body Yield 1000 lbs
Wall (inch)
I.D. (inch)
Drift Diameter (inch)
API
LSS
11.750
71.00
P-110
5470
2246
0.582
10.586
10.430
11.750
71.00
HCQ-125
7280
2552
0.582
10.586
10.430
11.750
71.00
Q-125
5760
2552
0.582
10.586
10.430
11.875
71.80
H2S-90
7190
1858
0.582
10.711
11.875
71.80
S-95
7190
1962
0.582
10.711
11.875
71.80
H2S-95
7190
1962
0.582
10.711
11.875
71.80
HCP-110
7190
2271
0.582
10.711
11.875
71.80
P-110
5290
2271
0.582
10.711
11.875
71.80
HCQ-125
7190
2581
0.582
10.711
11.875
71.80
Q-125
5630
2581
0.582
10.711
11.875
71.00
LS-140
7280
2859
0.582
10.586
10.430
11.875
71.80
LS-140
7190
2891
0.582
10.711
13.375
48.00
H-40
740
541
0.330
12.715
12.559
13.375
54.50
J-55
1130
853
0.380
12.615
12.459
13.375
54.50
K-55
1130
853
0.380
12.615
12.459
13.375
54.50
HCK-55
1400
853
0.380
12.615
12.459
13.375
54.50
LS-65
1140
1008
0.380
12.615
12.459
13.375
61.00
J-55
1540
962
0.430
12.515
12.359
13.375
61.00
K-55
1540
962
0.430
12.515
12.359
13.375
61.00
HCK-55
2040
962
0.430
12.515
12.359
13.375
61.00
LS-65
1620
1137
0.430
12.515
12.359
13.375
68.00
J-55
1950
1069
0.480
12.415
12.259
13.375
68.00
K-55
1950
1069
0.480
12.415
12.259
13.375
68.00
HCK-55
2850
1069
0.480
12.415
12.259
13.375
68.00
LS-65
2110
1264
0.480
12.415
12.259
13.375
68.00
L-80
2260
1556
0.480
12.415
12.259
13.375
68.00
HCL-80
2910
1556
0.480
12.415
12.259
13.375
68.00
N-80
2260
1556
0.480
12.415
12.259
13.375
68.00
HCN-80
2910
1556
0.480
12.415
12.259
13.375
68.00
C-90
2320
1750
0.480
12.415
12.259
13.375
68.00
S-95
2910
1847
0.480
12.415
12.259
13.375
68.00
T-95
2330
1847
0.480
12.415
12.259
13.375
68.00
C-95
2330
1847
0.480
12.415
12.259
13.375
68.00
HCP-110
2910
2139
0.480
12.415
12.259
13.375
68.00
P-110
2340
2139
0.480
12.415
12.259
13.375
72.00
LS-65
2430
1350
0.514
12.347
12.191
13.375
72.00
L-80
2670
1661
0.514
12.347
12.191
13.375
72.00
HCL-80
3470
1661
0.514
12.347
12.191
13.375
72.00
N-80
2670
1661
0.514
12.347
12.191
13.375
72.00
HCN-80
3470
1661
0.514
12.347
12.191
13.375
72.00
C-90
2780
1869
0.514
12.347
12.191
13.375
72.00
H2S-90
3470
1869
0.514
12.347
12.191
13.375
72.00
S-95
3470
1973
0.514
12.347
12.191
13.375
72.00
T-95
2820
1973
0.514
12.347
12.191
13.375
72.00
H2S-95
3470
1973
0.514
12.347
12.191
13.375
72.00
C-95
2820
1973
0.514
12.347
12.191
13.375
72.00
HCP-110
3470
2284
0.514
12.347
12.191
13.375
72.00
P-110
2890
2284
0.514
12.347
12.191
13.375
72.00
HCQ-125
3470
2596
0.514
12.347
12.191
13.375
72.00
Q-125
2880
2596
0.514
12.347
12.191
13.375
72.00
LS-140
3470
2908
0.514
12.347
12.191
13.375
72.00
V-150
2880
3115
0.514
12.347
12.191
13.375
80.70
H2S-90
4990
2098
0.580
12.215
12.059
13.375
80.70
S-95
4990
2215
0.580
12.215
12.059
13.375
80.70
H2S-95
4990
2215
0.580
12.215
12.059
13.375
80.70
HCP-110
4990
2565
0.580
12.215
12.059
13.375
80.70
P-110
4000
2565
0.580
12.215
12.059
13.375
80.70
HCQ-125
4990
2914
0.580
12.215
12.059
13.375
80.70
Q-125
4140
2914
0.580
12.215
12.059
13.375
86.00
S-95
6240
2378
0.625
12.125
11.969
13.375
86.00
HCP-110
6240
2754
0.625
12.125
11.969
13.375
86.00
P-110
4780
2754
0.625
12.125
11.969
13.375
86.00
HCQ-125
6240
3129
0.625
12.125
11.969
13.375
86.00
Q-125
5030
3129
0.625
12.125
11.969
O.D. (inch)
Grade
Internal Yield Pressure Minimum Yield (psi)
Joint Strength 1000 lbs
PE
STC
LTC
STC
STC
LTC
BTC
11.750
71.00
P-110
5470
9530
9530
9530
1506
2215
11.750
71.00
HCQ-125
7280
10840
10840
10840
1693
2448
11.750
71.00
Q-125
5760
10840
10840
10840
1693
2448
11.875
71.80
H2S-90
7190
7270
7270
7270
1129
1647
11.875
71.80
S-95
7190
8150
8150
8150
1153
1735
11.875
71.80
H2S-95
7190
8150
8150
8150
1141
1691
11.875
71.80
HCP-110
7190
9430
9430
9430
1329
1988
11.875
71.80
P-110
5290
9430
9430
9430
1329
1988
11.875
71.80
HCQ-125
7190
10720
10720
10720
1494
2198
11.875
71.80
Q-125
5630
10720
10720
10720
1494
2198
11.875
71.00
LS-140
7280
12140
12140
12140
1893
2730
11.875
71.80
LS-140
7190
12010
12010
12010
1671
2451
13.375
48.00
H-40
740
1730
1730
1730
322
607
13.375
54.50
J-55
1130
2730
2730
2730
514
909
13.375
54.50
K-55
1130
2730
2730
2730
547
1038
13.375
54.50
HCK-55
1400
2730
2730
2730
689
1194
13.375
54.50
LS-65
1140
3230
3230
3230
602
1052
13.375
61.00
J-55
1540
3090
3090
3090
595
1025
13.375
61.00
K-55
1540
3090
3090
3090
633
1169
13.375
61.00
HCK-55
2040
3090
3090
3090
798
1345
13.375
61.00
LS-65
1620
3660
3660
3660
697
1185
13.375
68.00
J-55
1950
3450
3450
3450
675
1140
13.375
68.00
K-55
1950
3450
3450
3450
718
1300
13.375
68.00
HCK-55
2850
3450
3450
3450
905
1496
13.375
68.00
LS-65
2110
4080
4080
4080
791
1318
13.375
68.00
L-80
2260
5020
5020
5020
952
1545
13.375
68.00
HCL-80
2910
5020
5020
5020
1093
1732
13.375
68.00
N-80
2260
5020
5020
5020
963
1585
13.375
68.00
HCN-80
2910
5020
5020
5020
1103
1732
13.375
68.00
C-90
2320
5650
5650
5650
1057
1683
13.375
68.00
S-95
2910
5970
5970
5970
1125
1812
13.375
68.00
T-95
2330
5970
5970
5970
1114
1772
13.375
68.00
C-95
2330
5970
5970
5970
1114
1772
13.375
68.00
HCP-110
2910
6910
6910
6910
1297
2079
13.375
68.00
P-110
2340
6910
6910
6910
1297
2079
13.375
72.00
LS-65
2430
4370
4370
4370
854
1408
13.375
72.00
L-80
2670
5380
5380
5380
1029
1650
13.375
72.00
HCL-80
3470
5380
5380
5380
1181
1850
13.375
72.00
N-80
2670
5380
5380
5380
1040
1693
13.375
72.00
HCN-80
3470
5380
5380
5380
1192
1850
13.375
72.00
C-90
2780
6050
6050
6050
1142
1798
13.375
72.00
H2S-90
3470
6050
6050
6050
1192
1850
13.375
72.00
S-95
3470
6390
6390
6390
1215
1935
13.375
72.00
T-95
2820
6390
6390
6390
1204
1893
13.375
72.00
H2S-95
3470
6390
6390
6390
1204
1893
13.375
72.00
C-95
2820
6390
6390
6390
1204
1893
13.375
72.00
HCP-110
3470
7400
7400
7400
1402
2221
13.375
72.00
P-110
2890
7400
7400
7400
1402
2221
13.375
72.00
HCQ-125
3470
8410
8410
8410
1577
2463
13.375
72.00
Q-125
2880
8410
8410
8410
1577
2463
13.375
72.00
LS-140
3470
9420
9420
9420
1763
2749
13.375
72.00
V-150
2880
10090
10090
10090
1887
2939
13.375
80.70
H2S-90
4990
6830
7340
2077
13.375
80.70
S-95
4990
7210
7210
2173
13.375
80.70
H2S-95
4990
7210
7210
2125
13.375
80.70
HCP-110
4990
8350
8350
2493
13.375
80.70
P-110
4000
8350
8350
2493
13.375
80.70
HCQ-125
4990
9490
9490
2765
13.375
80.70
Q-125
4140
9490
9490
2765
13.375
86.00
S-95
6240
7770
7750
2333
13.375
86.00
HCP-110
6240
9000
8980
2677
13.375
86.00
P-110
4780
9000
8980
2677
13.375
86.00
HCQ-125
6240
10220
10200
2969
13.375
86.00
Q-125
5030
10220
10200
2969
Related Resources:
