API Casing Data Tables Size 10.750
API Casing Data Tables Size 10.750.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal
Weight
T & C
Grade
Collapse
Pressure
(psi)
Internal Yield Pressure
Minimum Yield (psi)
Joint Strength
1000 lbs
Body Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
PE
STC
LTC
BTC
STC
LTC
BTC
API
LSS
10.750
45.50
K-55
2090
3580
3580
3580
528
931
715
0.400
9.950
9.794
9.875
10.750
45.50
HCK-55
3130
3580
3580
3580
659
1037
715
0.400
9.950
9.794
9.875
10.750
45.50
LS-65
2280
4230
4230
4230
576
916
845
0.400
9.950
9.794
9.875
10.750
45.50
N-80
2470
5210
5210
5210
701
1097
1040
0.400
9.950
9.794
9.875
10.750
45.50
HCN-80
3130
5210
5210
5210
799
1175
1040
0.400
9.950
9.794
9.875
10.750
51.00
J-55
2700
4030
4030
4030
565
891
801
0.450
9.850
9.694
10.750
51.00
K-55
2700
4030
4030
4030
606
1043
801
0.450
9.850
9.694
10.750
51.00
HCK-55
4420
4030
4030
4030
756
1160
801
0.450
9.850
9.694
10.750
51.00
LS-65
2870
4760
4760
4760
661
1026
946
0.450
9.850
9.694
10.750
51.00
L-80
3220
5860
5860
5860
794
1190
1165
0.450
9.850
9.694
10.750
51.00
HCL-80
4460
5860
5860
5860
906
1316
1165
0.450
9.850
9.694
10.750
51.00
N-80
3220
5860
5860
5860
804
1228
1165
0.450
9.850
9.694
10.750
51.00
HCN-80
4460
5860
5860
5860
916
1316
1165
0.450
9.850
9.694
10.750
51.00
C-90
3400
6590
6590
6590
879
1287
1311
0.450
9.850
9.694
10.750
51.00
H2S-90
4460
6590
6590
6590
916
1316
1311
0.450
9.850
9.694
10.750
51.00
S-95
4460
6960
6960
6960
937
1392
1383
0.450
9.850
9.694
10.750
51.00
T-95
3480
6960
6960
6960
927
1354
1383
0.450
9.850
9.694
10.750
51.00
H2S-95
4460
6960
6960
6960
927
1354
1383
0.450
9.850
9.694
10.750
51.00
C-95
3480
6960
6960
6960
927
1354
1383
0.450
9.850
9.694
10.750
51.00
HCP-110
4460
8060
8060
8060
1080
1594
1602
0.450
9.850
9.694
10.750
51.00
P-110
3660
8060
8060
8060
1080
1594
1602
0.450
9.850
9.694
10.750
51.00
HCQ-125
4660
9160
9160
9160
1213
1758
1820
0.450
9.850
9.694
10.750
51.00
Q-125
3740
9160
9160
9160
1213
1758
1820
0.450
9.850
9.694
10.750
51.00
LS-140
4460
10260
10260
10260
1356
1959
2039
0.450
9.850
9.694
10.750
55.50
HCK-55
5220
4430
4430
4430
843
1271
877
0.495
9.760
9.604
9.625
10.750
55.50
LS-65
3690
5240
5240
5240
736
1124
877
0.495
9.760
9.604
9.625
10.750
55.50
L-80
4020
6450
6450
6450
884
1303
1276
0.495
9.760
9.604
9.625
10.750
55.50
HCL-80
5950
6450
6450
6450
1010
1441
1276
0.495
9.760
9.604
9.625
10.750
55.50
N-80
4020
6450
6450
6450
895
1345
1276
0.495
9.760
9.604
9.625
10.750
55.50
HCN-80
5950
6450
6450
6450
1021
1441
1276
0.495
9.760
9.604
9.625
10.750
55.50
C-90
4160
7250
7250
7250
979
1409
1435
0.495
9.760
9.604
9.625
10.750
55.50
H2S-90
5950
7250
7250
7250
1021
1441
1435
0.495
9.760
9.604
9.625
10.750
55.50
S-95
5950
7660
7660
7660
1043
1524
1515
0.495
9.760
9.604
9.625
10.750
55.50
T-95
4290
7660
7660
7660
1032
1483
1515
0.495
9.760
9.604
10.750
55.50
H2S-95
5950
7660
7660
7660
1032
1483
1515
0.495
9.760
9.604
9.625
10.750
55.50
C-95
4290
7660
7660
7660
1032
1483
1515
0.495
9.760
9.604
9.625
10.750
55.50
HCP-110
5950
8860
8860
8860
1203
1745
1754
0.495
9.760
9.604
9.625
10.750
55.50
P-110
4610
8860
8860
8860
1203
1745
1754
0.495
9.760
9.604
9.625
10.750
55.50
HCQ-125
5950
10070
10070
10070
1351
1925
1993
0.495
9.760
9.604
9.625
10.750
55.50
Q-125
4850
10070
10070
10070
1351
1925
1993
0.495
9.760
9.604
9.625
10.750
55.50
LS-140
5950
11280
11280
11280
1510
2146
2233
0.495
9.760
9.604
9.625
10.750
60.70
L-80
5160
7100
7100
7100
983
1428
1398
0.545
9.660
9.504
10.750
60.70
HCL-80
7550
7100
7100
7100
1123
1579
1398
0.545
9.660
9.504
10.750
60.70
N-80
5160
7100
7100
7100
996
1473
1398
0.545
9.660
9.504
10.750
60.70
N-80
5160
7100
7100
7100
996
1473
1398
0.545
9.660
9.504
10.750
60.70
HCN-80
7550
7100
7100
7100
1136
1579
1398
0.545
9.660
9.504
10.750
60.70
C-90
5460
7980
7980
7980
1089
1544
1573
0.545
9.660
9.504
10.750
60.70
H2S-90
7550
7980
7980
7980
1136
1579
1573
0.545
9.660
9.504
10.750
60.70
S-95
7550
8430
8430
8430
1161
1670
1660
0.545
9.660
9.504
10.750
60.70
T-95
5590
8430
8430
8430
1148
1625
1660
0.545
9.660
9.504
10.750
60.70
H2S-95
7550
8430
8430
8430
1148
1625
1660
0.545
9.660
9.504
10.750
60.70
C-95
5590
8430
8430
8430
1148
1625
1660
0.545
9.660
9.504
10.750
60.70
HCP-110
7550
9760
9760
9760
1338
1912
1922
0.545
9.660
9.504
10.750
60.70
P-110
5880
9760
9760
9760
1338
1912
1922
0.545
9.660
9.504
10.750
60.70
HCQ-125
7550
11090
11090
11090
1503
2109
2184
0.545
9.660
9.504
10.750
60.70
Q-125
6070
11090
11090
11090
1503
2109
2184
0.545
9.660
9.504
10.750
60.70
LS-140
7550
12420
12420
12420
1680
2351
2446
0.545
