API Casing Data Tables Size 11.750 - 13.375
API Casing Data Tables Size 11.750 - 13.375.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal
Weight
T & C
Grade
Collapse
Pressure
(psi)
Internal Yield Pressure
Minimum Yield (psi)
Joint Strength
1000 lbs
Body Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
PE
STC
LTC
STC
STC
LTC
BTC
API
LSS
13.500
81.40
H2S-90
4860
6770
6770
1862
2119
0.580
12.340
13.500
81.40
S-95
4860
7140
7140
1948
2236
0.580
12.340
13.500
81.40
H2S-95
4860
7140
7140
1905
2236
0.580
12.340
13.500
81.40
HCP-110
4860
8270
8270
2235
2590
0.580
12.340
13.500
81.40
P-110
3910
8270
8270
2235
2590
0.580
12.340
13.500
81.40
HCQ-125
4860
9400
9400
2479
2943
0.580
12.340
13.500
81.40
Q-125
4030
9400
9400
2479
2943
0.580
12.340
13.625
88.20
H2S-90
5930
7220
7220
1801
2297
0.625
12.375
13.625
88.20
S-95
5930
7630
7630
1885
2425
0.625
12.375
13.625
88.20
H2S-95
5930
7630
7630
1843
2425
0.625
12.375
13.625
88.20
HCP-110
5930
8830
8830
2163
2808
0.625
12.375
13.625
88.20
P-110
4570
8830
8830
2163
2808
0.625
12.375
13.625
88.20
HCQ-125
5930
10030
10030
2399
3191
0.625
12.375
13.625
88.20
Q-125
4800
10030
10030
2399
3191
0.625
12.375
16.000
65.00
H-40
630
1640
1640
1640
439
781
736
0.375
15.250
15.062
16.000
75.00
J-55
1020
2630
2630
2630
710
1200
1178
0.438
15.124
14.936
16.000
75.00
K-55
1020
2630
2630
2630
752
1331
1178
0.438
15.124
14.936
16.000
75.00
LS-65
1020
3110
3110
3110
832
1394
1392
0.438
15.124
14.936
16.000
84.00
J-55
1410
2980
2980
2980
817
1351
1326
0.495
15.010
14.822
16.000
84.00
K-55
1410
2980
2980
2980
865
1499
1326
0.495
15.010
14.822
16.000
84.00
LS-65
1470
3520
3520
3520
957
1570
1567
0.495
15.010
14.822
16.000
84.00
N-80
1480
4330
4330
4330
1167
1898
1929
0.495
15.010
14.822
16.000
84.00
HCN-80
1910
4330
4330
4330
1342
1898
1929
0.495
15.010
14.822
16.000
84.00
HCP-110
1910
5960
5960
5960
1575
2518
2652
0.495
15.010
14.822
16.000
84.00
P-110
1480
5960
5960
5960
1575
2518
2652
0.495
15.010
14.822
16.000
84.00
HCQ-125
1910
6770
6770
6770
1773
2809
3014
0.495
15.010
14.822
16.000
84.00
Q-125
1480
6770
6770
6770
1773
2809
3014
0.495
15.010
14.822
16.000
95.00
N-80
2180
4950
4950
2161
2196
0.566
14.868
16.000
95.00
HCN-80
2580
4950
4950
2161
2196
0.566
14.868
16.000
95.00
HCP-110
2580
6810
6810
2866
3019
0.566
14.868
16.000
95.00
P-110
2230
6810
6810
2866
3019
0.566
14.868
16.000
95.00
HCQ-125
2580
7740
7740
3198
3431
0.566
14.868
16.000
95.00
Q-125
2230
7740
7740
3198
3431
0.566
14.868
16.000
97.00
N-80
2270
5030
5030
2194
2230
0.575
14.850
16.000
97.00
HCN-80
2990
5030
5030
2194
2230
0.575
14.850
16.000
97.00
HCP-110
2990
6920
6920
2910
3067
0.575
14.850
16.000
97.00
P-110
2340
6920
6920
2910
3067
0.575
14.850
16.000
97.00
HCQ-125
2990
7860
7860
3246
3485
0.575
14.850
16.000
97.00
Q-125
2340
7860
7860
3246
3485
0.575
14.850
16.000
109.00
J-55
2560
3950
3950
3950
1116
1772
1739
0.656
14.688
14.500
16.000
109.00
K-55
2560
3950
3950
3950
1181
1965
1739
0.656
14.688
14.500
16.000
109.00
N-80
3080
5740
5740
5740
1594
2489
1739
0.656
14.688
14.500
16.000
118.00
J-55
3170
4300
4300
4300
1224
1924
1889
0.715
14.570
14.382
16.000
118.00
K-55
3170
4300
4300
4300
1296
2131
1889
0.715
14.570
14.382
16.000
118.00
N-80
3680
6260
6260
6260
1741
2703
2747
0.715
14.570
14.382
18.625
87.50
H-40
630
1630
1630
1630
559
993
995
0.435
17.755
17.567
18.625
87.50
J-55
630
2250
2250
2250
754
1329
1368
0.435
17.755
17.567
18.625
87.50
K-55
630
2250
2250
2250
794
1427
1368
0.435
17.755
17.567
18.625
87.50
N-80
630
3270
3270
3270
1079
1887
1990
0.435
17.755
17.567
18.625
94.50
H-40
780
1760
1760
1760
609
1067
1068
0.468
17.689
17.501
18.625
94.50
J-55
780
2420
2420
2420
821
1427
1469
0.468
17.689
17.501
18.625
94.50
K-55
780
2420
2420
2420
865
1533
1469
0.468
17.689
17.501
18.625
94.50
N-80
780
3520
3520
3520
1174
2027
2137
0.468
17.689
17.501
18.625
106.00
H-40
1140
2000
2000
2000
703
1206
1208
0.531
17.563
17.375
18.625
106.00
J-55
1140
2740
2740
2740
948
1613
1661
0.531
17.563
17.375
18.625
106.00
K-55
1140
2740
2740
2740
998
1733
1661
0.531
17.563
17.375
18.625
106.00
N-80
1150
3990
3990
3990
1356
2292
2416
0.531
17.563
17.375
18.625
117.50
H-40
1500
2230
2230
2230
795
1342
1344
0.593
17.439
17.251
18.625
117.50
J-55
1510
3060
3060
3060
1072
1795
1849
0.593
17.439
17.251
18.625
117.50
K-55
1510
3060
3060
3060
1129
1929
1849
0.593
17.439
17.251
18.625
117.50
N-80
1620
4460
4460
4460
1534
2551
2689
0.593
17.439
17.251
Related Resources:
