Fixed Fastener Condition Projected Tolerance Zone Compensation Calculator
Calculators
Geometric Dimensioning & Tolerancing Training
This calculator calculates  position tolerances utilizing principles and concepts withinASME Y14.5-2009 and ASME Y14.5M - 1994, Geometric Dimensioning and Tolerancing (GD&T).
For the equations behind this calculator, see:
"Geometric Boundaries"
Interpretation and Application of
Open Description of Variables Used in Calculator
This calculator will calculate the required field compensating for the effects of the fastener projection.  Calculations assume a line-line case at tolerance and feature-of-size maximum departure.
Notes:
  1. Units may be given as inches, mm, meters or whatever.
  2. Units DO NEED to be consistant (e.g. all inches or all mm).
Fixed Fastener Condition True Position and Projection Zone Calculator
Fastener (Shaft)
Diameter (MMC)
Hole Diameter
(MMC)
Hole Tolerance
(Position MMC)
Fastener (Shaft)
Tolerance (RFS)
Thread Engagement
Fixed Fastener Condition GD&T Specifications
Related Resources:
