Belleville Washer Design Formulae and Calculator
Spring Design and Engineering Equations and Calculators
Belleville Washer Design Formula and Calculator
When a load is applied to a Belleville washer it tends to flatten causing radial and circumferential strains. This elastic deformation creates the spring action. A typical Belleville washer is shown in Figure 1.
Figure 1 - Typical Belleville Washer
Preview: Belleville Design Calculator
Belleville washers are capable of providing very high loads at small deflections. Stress is not distributed uniformly in Belleville washers. The highest stress occurs at the top inner edge and can be estimated with the following equation:
S = ( EM · f · R ) / ( 1 - µ2 ) ( t / a2 )
Eq. 1a
a = OD / 2
Eq. 1b
R = OD / ID
S = Bending stress, lbs/in2, (N.mm2)
EM = Modulus of Elasticity, lbs/in2, (N.mm2)
µ = Poisson's ratio
f = washer deflection, in (mm)
t = washer thickness, in (mm)
a = radius, in (mm)
OD = outside diameter, in (mm)
ID = Inside diiameter, in (mm)
R = Dimension factor
The failure rate of a curved washer is determined using the following equation:
λSP = λSP,B · ( S / Ts )3 · Ccs · CR · CM
A generalized equation that adjusts the base failure rate of a curved washer considering anticipated operating conditions can be established:
Eq. 3
λSP = λSP,B · CE · Ct · CD · Cf · CY · CS · CCS · CR · CM
where:
λSP = Failure rate of torsion spring, failures/million hours
λSP,B =
Base failure rate for torsion spring, 14.3 failures/million hours
CE = Multiplying factor which considers the effect of the material elasticity modulus on the base failure rate
Eq. 4
CE = ( EM / 28.5 x 106 )3
Ct = Multiplying factor which considers the effect of the material thickness on the base failure rate
Eq. 5
Ct = ( t / 0.025 )3
CD = Multiplying factor which considers the effect of washer diameter on the base failure rate
Eq. 6
CD = ( 1.20 / OD )6
CY = Multiplying factor which considers the effect of material tensile strength on the base failure rate
Eq. 7
CY = ( 190 x 103 / Ts )3
Ts = Tensile Strength, lbs/in2, (N/mm2)
Cf = Multiplying factor which considers the effect of washer deflection on the base failure rate
Eq. 8
Cf = ( f / 0.055 )3
CNW = Multiplying Factor which considers the number of waves on the base failure rate
Eq. 9
CNW = ( 5 / NW )2
CCS = Multiplying factor which considers the effect of a corrosive environment on the base failure rate
Eq. 10a
CCS
= 0.100 If CR ≤ cycles/min
Eq. 10b
CCS
= CR / 300 ) For 30 cycles/min < CR ≤ 300 cycles min,
Eq. 10c
CCS = ( CR / 300 )3 ForCR > 300 cycles/min,
CR = Multiplying factor which considers the effect of a corrosive environment on the base failure rate
Eq. 11
CR
= 1.0 unless or greater than 1.0 with user's experience with the spring and the operating environment.
CM = Multiplying factor which considers the effect of the manufacturing process on the base failure rate
Eq. 12
CM = 1.0 a higher value for the multiplying factor is used based on previous experience with the manufacturer.
CS = Multiplying factor for compressive stress
Eq. 12
CS = ( 6 / ( π · ln R )3 ) · ( R - 1 / ( ln R) - 1 ) · ( (R - 1 ) / 2 ) · ( ( R - 1 )2 / R2 )
Handbook of of Reliability Predictions Procedure for Mechanical Equipment
Logistics Technology Support
CARDEROCKDIV, NSWC-11
2011
