Wave Washer Design Formula and Calculator
Spring Design and Engineering Equations and Calculators
Wave washers are used to apply moderate thrust loads when radial space is limited. A typical wave washer is shown in Figure 1.
Figure 1 - Typical Wave Washer
Typical Wave Washer
Preview: Wave Washer Design Calculator
The stress on a curved washer is:
S = (0.3 · π · EM · f · t · N2) / (D)2
Eq. 1a
D
= ( OD + ID ) / 2, in (mm)
S = Bending stress, lbs/in2, (N.mm2)
EM = Modulus of Elasticity, lbs/in2, (N.mm2)
f = washer deflection, in (mm)
t = washer thickness, in (mm)
N = Number of waves
D = Mean diameter, = ( OD + ID )/2 , in (mm)
OD = outside diameter, in (mm)
ID = Inside diiameter, , in (mm)
The failure rate of a curved washer is determined using the following equation:
λSP = λSP,B · ( S / Ts )3 · Ccs · CR · CM
A generalized equation that adjusts the base failure rate of a curved washer considering anticipated operating conditions can be established:
Eq. 3
λSP = λSP,B · CE · Ct · CD · CY · Cf · CNW · CCS · CR · CM
where:
λSP = Failure rate of torsion spring, failures/million hours
λSP,B =
Base failure rate for torsion spring, 14.3 failures/million hours
CE = Multiplying factor which considers the effect of the material elasticity modulus on the base failure rate
Eq. 4
CE = ( EM / 28.5 x 106 )3
Ct = Multiplying factor which considers the effect of the material thickness on the base failure rate
Eq. 5
Ct = ( t / 0.025 )3
CD = Multiplying factor which considers the effect of washer diameter on the base failure rate
Eq. 6
CD = ( 1.20 / OD )6
CY = Multiplying factor which considers the effect of material tensile strength on the base failure rate
Eq. 7
CY = ( 190 x 103 / Ts )3
Ts = Tensile Strength, lbs/in2, (N/mm2)
Cf = Multiplying factor which considers the effect of washer deflection on the base failure rate
Eq. 8
Cf = ( f / 0.055 )3
CNW = Multiplying Factor which considers the number of waves on the base failure rate
Eq. 9
CNW = ( 5 / NW )2
CCS = Multiplying factor which considers the effect of a corrosive environment on the base failure rate
Eq. 10a
CCS
= 0.100 If CR ≤ cycles/min
Eq. 10b
CCS
= CR / 300 ) For 30 cycles/min < CR ≤ 300 cycles min,
Eq. 10c
CCS = ( CR / 300 )3 ForCR > 300 cycles/min,
CR = Multiplying factor which considers the effect of a corrosive environment on the base failure rate
Eq. 11
CR
= 1.0 unless or greater than 1.0 with user's experience with the spring and the operating environment.
CM = Multiplying factor which considers the effect of the manufacturing process on the base failure rate
Eq. 12
CM = 1.0 a higher value for the multiplying factor is used based on previous experience with the manufacturer.
Handbook of of Reliability Predictions Procedure for Mechanical Equipment
Logistics Technology Support
CARDEROCKDIV, NSWC-11
2011
