Wind Force on Flag Pole Cylinder Formula and Calculator
Fluids Engineering and Design
Civil Engineering and Design
Wind Force on Flag Pole Cylinder Formula and Calculator (Airflow around a Cylinder Formula)
The characteristic drag coefficient plot for cylinders placed normal to the fluid flow is similar to the plot for spheres. The plot shown in Fig. 1 is for infinitely long cylinders, since there is additional wake drag at the cylinder ends. In calculating the Reynolds number, the cylinder diameter should be used as the characteristic dimension.
Preview Premium Membership Calculator Wind Force on Flag Pole Cylinder
Drag Coefficient for Cylinder
Fig. 1 - Drag Coefficient for Cylinder
Density of air
Eq. 1,
ρ = p / ( R T )
Kinematic Viscosity
Eq. 2,
v = µ /ρ
The characteristic dimension of a cylinder is its diameter. The Reynolds number is
Eq. 3
Re = L v / ν = Dv / ν
Frontal area of the flagpole
Eq. 4
A = DL
Drag Force on the flagpole is
Eq. 5
FD = CD A ρ v2 / 2
FD = Drag Force on the flagpole, N
D
= Pole or cylinder diamater, m
L = length of pole, m
µ = absolute viscosity (1.709 x 10-5 Pa · s)
CD = drag coefficient based on Reynolds number - see Fig. 1
ρ = density of air ~ 1.276 kg/m3 (temperature dependent)
v = Wind speed, m/s
ν = Kinematic viscosity, m2/s
p = pressure, kPa
R = Specific gas constant for Air 287.03 J / kg·K
T = Temperature, K
Re = Reynolds number,dimensionless
A = Frontal area of pole, m2
  • Civil Engineering Reference Manual, Fifteeth Edition
