Triangular Clamping Toggle Design Formula and Calculator
Triangular Clamping Toggle Mechanism Design Formula and Calculator
Triangular Force Reducer arm clamp design with forces applied and reaction forces calculator.
Preview: Triangular Clamping Toggle Mechanism Calculator
Q = P [ ( l + h · f + r · fo ) / ( l1 - h1 · f1 - r · fo ) ]
P = Q / [ ( l + h · f + r · fo ) / ( l1 - h1 · f1 - r · fo ) ]
When
l1 ≥ l and P ≥ Q
Figure 1
Q = force applied to handle. lbf, (N)
P = clamping force, lbf. (N)
f = coefficient of friction of contact surface = 0.1 to 0.15
fo = coefficient of friction (axles and pivot pins) = 0.1 to 0.15
f1 = coefficient of friction of pin contact surface = 0.1 to 0.15
l, l1 = length as indicated. in, (mm)
h, h1 = distance as indicated. in, (mm)
r = radius of pivot hole. in, (mm)
Handbook of Machining and Metalworking Calculations
Ron A. Walsh
2001
