Distance Between Bearings on Shaft Design Formula and Calculator
Bearing Engineering and Knowledge Application Menu
The shaft which the bearings are installed on are potentially subject to both bending and torsion forces and must be accounted for in the design installation and spacing of bearings. Also, a factor of or margin of safety must be applied. The maximumbearing distance of separation may be calculated as follows
Instead of computing the transverse deflection, the maximum distance between the bearings (in meters) may be computed by the empirical formula to limit the transverse deflection to 0.8mm/m of length
Distance between bearings (Reference 1)
L = 1500 / ( n + 1500 ) c D( 2/3 )
Values of constant c
Type of shaft loading
Coefficient c
Allowable stress
MPa
kpsi
Shaft heavily loaded, subjected to shock, or reversed under full load
0.82
17
2.5
Line shafts and countershafts,
1.1
27
4.0
Line shafts or bar with pulleys close to the bearings
1.56
44
6.4
Alternatively
The shaft-bearing spacing formula is based on the formula for critical speed for a shaft having fully flexible bearings at both ends.
Eq. 2 (Reference 2)
L = [ 3.21 D ) / n ](1/2) ( E / W1 ](1/4)
Where
D = diameter of solid shaft, m (in)
L = Unsupported distance between bearings
n = speed, rpm
E = Modulus of elasticity
W1 = weght in lbs of shaft
Note: The minimum minimum spacing for RIGID bearings should exceed 20 shaft diameters when possible to facilitate alignment
Bearing Spacing Design Graph
Figure 1 Bearing Spacing Design Graph - Click on Image to enlarge
References
1. Lingaiah, K., and B. R. Narayana Iyengar, Machine Design Data Handbook, Engineering College Cooperative, Bangalore, India, 1962.
2. Aqualoy Propeller Shafting
