Ball and Roller Bearing Analysis Loading and Selection Formulas and Calculator
Bearing Application, Specifications and Engineering
Ball and Roller Bearing Analysis for Loading and Selection Formulas and Calculator
Preview: Ball and Roller Bearing Analysis for Loading and Selection Calculator
The minimum required basic load rating (load for which 90% of the bearings from a given population will survive 1 million revolutions) is given by:
This is sometimes called the bearing life regression equation.
C = P L( 1/a )
where
C = minimum required basic load rating
P = design radial load
L = design life (in millions of revolutions)
a = 3 for ball bearings; 3/10 for roller bearings
When a ball bearing is subjected to both radial and axial loads, an equivalent radial load must be used in the basic load rating equation. The equivalent radial load is
Peq = X · V · Fr + Y · Fa
where
Peq = equivalent radial load
Fr = applied constant radial load
Fa = applied constant axial (thrust) load
For radial contact, deep-groove ball bearings:
V = 1 if inner ring rotating, 1.2 if outer ring rotating
if Fa / ( V · Fr ) > e, then X = 0.56 and Y = 0.840 ( Fa / Co )-0.247
where:
Eq. 3
e = 0.513 ( Fa / Co )0.236
Co = basic static load rating from bearing catalog
if Fa / ( V · Fr ) ≤ e, then x = 1 and Y = 0
Eq. 4
FR
= FD ( ND / NR )1/a = FD ( LD ND / ( LR NR ) )1/a
where:
FR = catalog radial rating (lb or kN)
LR = catalog rated life (hr)
NR = catalog rated speed (rev per min)
FD = required radial design load (lb or kN)
LD = required design life (hr)
ND = required design speed (rev per min)
Budynas, Richard G., and J. Keith Nisbett, Shigley's Mechanical Engineering Design, 8th ed., New York: McGraw-Hill, 2008.
