Bending, Deflection and Stress Equations Calculator for Beam Supported on Both Ends Loaded Two equal Loads
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Supported on Both Ends Loaded Two equal Loads.
Open
Stress and Deflection Beam Supported Both Ends Loaded Two Equal Loads Calculator
Stress between nearest load and support point
Stress between the two loads
Stress at each load application and all points between
Deflection between nearest load and support point
Deflection between loads
Maximum Deflection at Center
Deflection at loads
Deflection at loads
E = Modulus of Elasticity psi
(N/mm2)
W = Load on Beam lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection (Positive Upward Deflection, Negative Downward inches (mm)
a = Some distance as indicated inches (mm)
v = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 262
