Combined Loading on Rectangular Beam or Shaft Combined Loading Simply Supported Equations and Calculator
Combined Loading on Rectangular Beam or Shaft in Direct Tension and Bending Equation and Calculator:
Maximum Nominal
Shear Stress
h = Height of Beam inches (mm)
b = Width of Beam inches (mm)
Fy =
Applied Load lbs (N)
Fx = Applied Load lbs (N)
σ' a =
Stress, Tensile or Compressive Lbs/in2 (N/mm2)
σ' b = Stress, Tensile or Compressive Lbs/in2 (N/mm2)
τ'a = Stress , Max. Nominal Shear Lbs/in2 (N/mm2)
τ'b = Stress , Max. Nominal Shear Lbs/in2 (N/mm2)
  1. Any Machinery's Handbook published since 1931 or,
  2. Machinery's Handbook, 21st Edition, Page 404 or,
  3. Machinery's Handbook, 23st Edition, Page 260 or,
  4. Machinery's Handbook, 27st Edition, Page 261
