Beam Deflection Free and Guided on One End, Rigid one End With Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Free and Guided on One End, Rigid one End With Uniform Load.
Beam Free and Guided on One End Stress and Deflections Calculator
Open
Beam Stress at Any Point
Beam Stress at the fixed support
Beam Deflection at specified point
Beam Deflection at the free end
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s = Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 410 or,
  • Machinery's Handbook, 23st Edition, Page 266 or,
  • Machinery's Handbook, 27st Edition, Page 267
