Bending, Deflection and Stress Equations Calculator for
Beam Supported on Both Ends With Overhanging Supports of equal Length and Uniform Loading
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Supported on Both Ends With Overhanging Supports of equal Length and Uniform Loading .
Open
Deflection and Stress Beam For Supported on Both Ends Calculator
Stress between nearest support point and outer end
Stress between the two supports
Stress at load center
Stress at supports
If cross-section is constant, the greater of these is the maximum stress.
If l is greater than 2c, the stress is zero at points on both sides of the center.
If cross-section is constant and if l = 2.828c, the stresses at supports and center are equal and opposite, and are:
Deflection between support point and outer end
Deflection between supports
Deflection at the ends
Deflection at center
If l is between 2c and 2.449c, there are maximum upward deflections at points
on both sides of the center, which are,
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
u = Some distance as indicated inches (mm)
c = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
