Bending, Deflection and Stress Equations Calculator for
Beam with End Overhanging Supports and a Single Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with End Overhanging Supports and a Single Load.
Open
Deflection, Stress Beam End Overhanging Supports and Single Load Calculator
Stress between load and nearest support
Stress between the two supports
Stress at support nearest load
Deflection between load nearest (adjacent support)
Deflection between supports
Deflection between non-loaded end and nearest support
Deflection at the load
Deflection at the unloaded ends
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
y = Deflection inches (mm)
u = Some distance as indicated inches (mm)
c = Some distance as indicated inches (mm)
w = Some distance as indicated inches (mm)
d = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 407 or,
  • Machinery's Handbook, 23st Edition, Page 263 or,
  • Machinery's Handbook, 27st Edition, Page 264
