Beam Deflection and Stress Equations Calculator for Beam Ends Overhanging Supports and a Two Equal Loads Applied at Symmetrical Locations
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations.
Open
Beam Stress, Beam Deflection Two Equal Loads Applied Symmetrical Locations Calculator
Beam Stress between loads and nearest support
Beam Stress between the two supports
Beam Stress at supports and all point along length  between supports
Beam Deflection between load nearest (adjacent) support
Beam Deflection between supports
Beam Deflection at the loads
Beam Deflection at the center of the beam
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
c = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 407 or,
  • Machinery's Handbook, 23st Edition, Page 263 or,
  • Machinery's Handbook, 27st Edition, Page 264
