Combined Offset Link, Circular Cross Section, in Direct Compression
Combined Loading Offset Link, Circular Cross Section, in Direct Compression Equation and Calculator:
Circular Shaft in Direct Tension and Torsion
Maximum Nominal
Shear Stress
d = Diameter inches (mm)
e = Distance inches (mm)
F =
Applied Load lbs (N)
σ' a =
Stress, Tensile or Compressive Lbs/in2 (N/mm2)
σ' b = Stress, Tensile or Compressive Lbs/in2 (N/mm2)
τ'a = Stress, Max. Nominal Shear Lbs/in2 (N/mm2)
τ'b = Stress, Max. Nominal Shear Lbs/in2 (N/mm2)
  1. Any Machinery's Handbook published since 1931 or,
  2. Machinery's Handbook, 21st Edition, Page 404 or,
  3. Machinery's Handbook, 23st Edition, Page 260 or,
  4. Machinery's Handbook, 27st Edition, Page 261
