Tensile Thread Stress Area Equation and Calculator - 100 ksi and More
Standard ANSI Hardware
Fastener - Bolt Design Calculations
This calculator calculates the tensile stress area of a external screw thread of a fastener. Use this calculator for materials over 100,000 psi ultimate tensile strength.
Open Calculator
This calculator will calculate the unknown for the given conditions. Two (2) inputs are required, See the application illustration at bottom of page.
Thread Stress Area
At = Tensile Strength Area of Screw Thread.
Esmin = MinimumPitch Diameter of External Thread - Thread Engineering Data Chart
n = Number of threads per inch
This equation is a more conservative extimation of actual thread stress area as opposed to the equation for Tensile Thread Stress Area 100 ksi and Less.
Bolt thread representation
Example; For a 1/2 - 13 UNC - 2A, see Thread Engineering Data Chart for minimum pitch diameter data.
Esmin = .4435
n = 13
At = 3.1416 (.4435/2 - 0.16238/13)2
At = .13757 = (Thread Stress Area)
