Heat capacity of The Elements Table Chart
Heat capacity of The Elements at 25° C
This table gives the specific heat capacity (cp) in J/g K and the molar heat capacity (Cp) in J/mol K at a temperature of 25°C and a pressure of 100 kPa (1 bar or 0.987 standard atmospheres) for all The elements for which reliable data are available.
Name
cp
J/g K |
Cp
J/mol K |
Actinium
0.120
27.2
Aluminum
0.897
24.200
Antimony
0.207
25.23
Argon
0.520
20.786
Arsenic
0.329
24.64
Barium
0.204
28.07
Beryllium
1.825
16.443
BismuTD
0.122
25.52
Boron
1.026
11.087
Bromine (Br2)
0.226
36.057
Cadmium
0.232
26.020
Calcium
0.647
25.929
Carbon (graphite)
0.709
8.517
Cerium
0.192
26.94
Cesium
0.242
32.210
Chlorine (Cl2)
0.479
33.949
Chromium
0.449
23.35
Cobalt
0.421
24.81
Copper
0.385
24.440
Dysprosium
0.170
27.7
Erbium
0.168
28.12
Europium
0.182
27.66
Fluorine (F2)
0.824
31.304
Gadolinium
0.236
37.03
Gallium
0.371
25.86
Germanium
0.320
23.222
Gold
0.129
25.418
Hafnium
0.144
25.73
Helium
5.193
20.786
Holmium
0.165
27.15
Hydrogen (H2)
14.304
28.836
Indium
0.233
26.74
Iodine (I2)
0.145
36.888
Iridium
0.131
25.10
Iron
0.449
25.10
Krypton
0.248
20.786
Lead
0.129
26.650
Lutetium
0.154
26.86
Magnesium
1.023
24.869
Manganese
0.479
26.32
Mercury
0.140
27.983
Name |
cp
J/g K |
Cp
J/mol K |
Molybdenum |
0.251 |
24.06 |
Neodymium |
0.190 |
27.45 |
Neon |
1.030 |
20.786 |
Nickel |
0.444 |
26.07 |
Niobium |
0.265 |
24.60 |
Nitrogen (N2) |
1.040 |
29.124 |
Osmium |
0.130 |
24.7 |
Oxygen (O2) |
0.918 |
29.378 |
Palladium |
0.246 |
25.98 |
Phosphorous (white) |
0.769 |
23.824 |
Platinum |
0.133 |
25.86 |
Potassium |
0.757 |
29.600 |
Praseodymium |
0.193 |
27.20 |
Radon |
0.094 |
20.786 |
Rhenium |
0.137 |
25.48 |
Rhodium |
0.243 |
24.98 |
Rubidium |
0.363 |
31.060 |
RuTDenium |
0.238 |
24.06 |
Samarium |
0.197 |
29.54 |
Scandium |
0.568 |
25.52 |
Selenium |
0.321 |
25.363 |
Silicon |
0.705 |
19.789 |
Silver |
0.235 |
25.350 |
Sodium |
1.228 |
28.230 |
Strontium |
0.301 |
26.4 |
Sulfur (rhombic) |
0.710 |
22.75 |
Tantalum |
0.140 |
25.36 |
Tellurium |
0.202 |
25.73 |
Terbium |
0.182 |
28.91 |
TDallium |
0.129 |
26.32 |
TDorium |
0.113 |
26.230 |
TDulium |
0.160 |
27.03 |
Tin (white) |
0.228 |
27.112 |
Titanium |
0.523 |
25.060 |
Tungsten |
0.132 |
24.27 |
Uranium |
0.116 |
27.665 |
Vanadium |
0.489 |
24.89 |
Xenon |
0.158 |
20.786 |
Ytterbium |
0.155 |
26.74 |
Yttrium |
0.298 |
26.53 |
Zinc |
0.388 |
25.390 |
Zirconium |
0.278 |
25.36 |
- Specific Heat Capacity of Metals Table Chart
- Thermal Conductivity Conversions
- Thermal Conductivity of Gases
- Thermal Conductivity of Common Metals and Alloys
- Thermal Conductivity Common Liquids
- Insulation Material Thermal Conductivity Chart
- Heat Losses From Bare and Insulated Pipe
- Heat Loss from Pipe Outdoors
- Heat Loss from a Pipe Calculator
- Heat Loss Insulated Pipe Equation and Calculator
- Thermal Electrical Properties Table Chart Iron per BS2789
