Storage Tank Baffle Design Excel Spreadsheet Calculator
Download: Storage Tank Baffle Design Excel Spreadsheet Calculator
Baffles are required in almost all mixing applications. This excel spreadsheet template contains a series of calculation sheets to assist you in calculating the baffles dimension and position in a tank, when the tank has a central agitator. Please note that if agitator is off-centered normally is not needed to install the baffles, as the effect is relatively similar, with a more clean installation. The main objectives are to provide a reference about baffles dimension and installation distances details a compare results between more than one calculation method. Metric and Imperial unit calculations are included.
Credit: Daniel de la Torre
