Pump Sizing Design Calculations Excel Spreadsheet Calculator
Download: Pump Sizing Design Calculations Excel Spreadsheet Calculator
Preview: Pump Sizing Design Calculations Excel Spreadsheet Calculator
Data input and calculation results:
Flowrate
Density
Viscosity
Vapor Pressure
Differential DP
Differential Head
Hydraulic power
NPSH available
Suction Condition
Pressure
Static Head
Equipment DP
Misc DP
Piping
Length
Pipe Diameter
Sch/ Thick
Pipe ID
Roughness
Fittings
Elbows, 90LR
Elbows, 45LR
Tees, Thru
Tees, Branch
Ball Valves
Butterfly Valves
Gate Valves
Globe Valves
Check Valves
Plug Valves
Pipe Entrance
Velocity
Reynold's No.
Pipe DP
Suction Pressure
Technical References
Society of Chemical Engineers (AlChE)
