Vibration and Shock Load Excel Spreadsheet Calculations
Vibration Design and Engineering
Beam Deflection and Stress Formulas and Calculators
Vibration and Shock Load Excel Spreadsheet Calculator
Note: Accessing this resource requires an active Premium Annual Membership with Engineers Edge
Download: Vibration and Shock Load Excel Spreadsheet Calculator
The inertia forces of rotating and oscillating machinery cause elastic supports to vibrate. Vibration amplitudes can be reduced by installing vibration damping mounting pads or springs.
Calculations:
- Simple Vibrating Systems Calculations
- Undamped Vibrations Calculations
- Forced Un-Damped Vibrations Calculations
- Damped, (Viscous) Forced Vibrations v
- Critical Damping Calculations
- Transmissibility (TR) v
- Series Springs Combined Stiffness Calculations
- Parallel Springs Combined Stiffness Calculations
- Critical Speed of Rotating Shaft Calculations
- Beam Stiffness (k), Deflection (x), and Natural Frequency ( f ) Calculations
- Plate Natural Frequency (f) Calculations
- Rectangular Plate Natural Frequency (f) Calculations
- Circular Plate Natural Frequency (f) Calculations
- Balancing Rotating Shafts Calculations
- Masses in Different Planes Calculations
- Forced, Steady State Vibration Example Calculations
- Vertical Vibration Damper Selection Calculations
- Vibration Isolator Selection Calculations
- Vibration Isolator Vendors v
- Shock Loads Calculations
- Free Fall Impact Shock Calculations
- Shock Impulse Deflection Calculations
- General Math Tools and Calculations
- Mechanical Vibrations, Fifth Edition | Engineers Edge | www.engineersedge.com
- Shock and Vibration Handbook | Engineers Edge | www.engineersedge.com
- Helicopter Calculations and Design Vibrations and Dynamic Stability | Engineers Edge | www.engineersedge.com
- Engineering Vibration Handbook | Engineers Edge | www.engineersedge.com
- Theory of Vibration | Engineers Edge | www.engineersedge.com
- Vibration Terms and Definitions | Engineers Edge
- Shock and Vibration Response Equations | Engineers Edge | www.engineersedge.com
