Solid Isosceles Triangle Torsional Deformation and Stress Torsional Deformation Stress Equation and Calculator
Torsional Deformation and Stress Solid Isosceles Triangle Section Equations and Calculator.
Preview Torsional Deformation and Stress Solid Isosceles Triangle Section Calculator
θ = T L / K G
Polar Moment of Inertia
Shear Stress
τ = T / Q
Angle α
α = cot [ b / (a/2) ]
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
a = Distance as indicated (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
Q = Polar Moment of Inertia (in4, mm4) for section
