Shaft with One Spline Deflection, Stress Equation and Calculator
Torque Applied Deformation and Stress of a Shaft with One Spline Equations and Calculator
Preview
Torque Applied Deformation and Stress of a Shaft with One Spline Section Calculator
K = 2Cr4
Varies with b / r as follows
For:
0   ≤   b / r ≤   0.5
Where 0.2  ≤   a / b   ≤   1.4
θ = ( T L ) / ( K G )
Shear Stress Maximum
At M:
Where B varies with b / r as follows:
for 0 ≤ b / r ≤ 0.5
for 0.2 ≤ a / b ≤ 1.4
θ = angle of twist (radians),
r = radius (in, mm),
a,b = Distance as shown (in, mm),
