Shaft with Four Keyways Torque Applied Deformation and Stress Equations and Calculator
Torque Applied Deformation and Stress of a Shaft with Four Keyways Equations and Calculator
Torque Applied Deformation and Stress of a Shaft with Keyway Section Calculator
Preview
Torque Applied Deformation and Stress of a Shaft with Four Keyway Section Calculator
K = 2Cr4
Varies with b / r as follows
For:
0   ≤   b / r ≤   0.4
Shaft with four Keyways Section Calculator
Where 0.3   ≤   a / b   ≤   1.2
Torque Applied Deformation and Stress of a Shaft with four Keyways Section Calculator
θ = ( T L ) / ( K G )
Shear Stress Maximum
At M:
Where B varies with b / r as follows:
for 0.2≤ b / r ≤ 0.4
for 0.5 ≤ a / b ≤ 1.2
θ = angle of twist (radians),
r = radius (in, mm),
a,b = Distance as shown (in, mm),
