Reaction and deflection Case 5L Roarks Formulas for Stress and Strain Equations and Calculator
Reaction and deflection formulas for in-plane loading of elastic frame with mounting ends fixed and distributed load on the right vertical member formulas and calculator. Roark's Formulas for Stress and Strain, Seventh Edition, Table 8.2 reference loading number 5L.
The formulas given assume the frames to have rigid corners; however, corrections can be made easily once the rigidity of a given corner design is known by making use of the concentrated angular displacement loading with the displacement positioned at the corner.
Loading Configuration
Preview: Frame Deflections with distributed load on the right vertical member Calculator
Deformation equations:
Loading CHH
Loading CHV
Loading CHM
Loading CVV
Loading CVM
Loading CMM
Loading terms for distributed load on the right vertical member:
Where used:
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
